vinesh Report post Posted 02/21/2005 10:33 AM Hi there, i have the following vb script Dim SayNumber, WavPath, SafePayRefNr RefNr = "$RV[RefNr]" WavPath = "Sound\Number\" SayNumber = Digits(RefNr) SayNumber = WavPath & Replace(SayNumber, ",", " ,Sound\Number\") SayNumber = "Sound\SMP\SMP 017.wav ," & SayNumber Set vg = CreateObject("VoiceGuide.CommandLink") vg.Play_Start $RV_LINEID, SayNumber set vg = Nothing Set vg = CreateObject("VoiceGuide.CommandLink") vg.Script_Goto $RV_LINEID, "","TransactionSMS" set vg = Nothing What it needs to do is say the reference number out and then redirect to another sound file module, what currently happens is that it plays 1 sec of the SayNumber sound file and then just skips to the "TransactionSMS" module. If i take off the goto part it pays fine but then even if i put a success or timeout {0} to go to the next module nothing happens... Please help Share this post Link to post
SupportTeam Report post Posted 02/21/2005 09:21 PM Create the filename in a VBScript module like you do right now but just save the filename to your own RV. Then use a Play module to play the sound file specified in the RV. Share this post Link to post
SupportTeam Report post Posted 02/22/2005 10:54 AM Or just add your own "Say Number" function to the lib_num2wav.vbs file, and then you will be able to use your custom function directly form within the Say Numbers module... Share this post Link to post
