Guest Geoff Report post Posted 02/22/2005 05:52 AM I was reading your feature list, and it says the Enterprise version is needed for ISDN. I was under the impression that ISDN required an Enterprise version with a 30 line license. [as per "VoiceGuide for ISDN"] Is it now possible to purchase an ISDN version of VoiceGuide for only 1 or 4 lines as seems to be indicated in your feature list and buy now pages? Thanks, Geoff Share this post Link to post
SupportTeam Report post Posted 02/22/2005 06:34 AM If you want 'VoiceGuide for ISDN' license then that version is only available in Enterprise or Enterprise+Dialer. The minimum line count is 24 lines if T1 connections are used and 30 lines if E1 connections are used. You cannot buy a 4 line "VG for ISDN". Share this post Link to post
Guest Geoff Report post Posted 02/22/2005 07:27 AM Thanks. Still not entirely clear.. Your price list says the Enterprise version is available for 1,4, 8... lines. The feature list says the Enterprise version works with ISDN. Putting these two points together is confusing, in light of your answer. Thanks Geoff Share this post Link to post
SupportTeam Report post Posted 02/22/2005 08:22 AM Enterprise comes in non-ISDN and ISDN versions. We'll see how we can make the Features list clearer on this point. Share this post Link to post
Guest Geoff Report post Posted 02/22/2005 09:52 AM OK, that clears it up. Regards, Geoff Share this post Link to post
