Multiple Surveys
I am looking at this system for running multiple surveys basically what I need is:
1. Enter the survey code > Branch to that survey
2. Store survey results to a database table
3. Validation e.g. Press 1,2,3
4. Error correction e.g. press # if you make a mistake
Need to use TTS which I think this does, also does it support Voice recognition ? or is it just keypad entry
Thx
Adam
VoiceGuide can do what you describe above, and is used in a number of similar applications already.
Please see our WWW from where you can download the fully working evaluation version of the software.
The demonstrations supplied will get you running in a matter of minutes.
Voice Recognition is not at this stage available for general release, but we can put together a Voice Recognition system for you if you'd like. Please note that cost of Voice Recognition is over $1000/port.
Ive got the trial version
1. How can I test it offline? i.e. on my laptop here.
2. How to I branch to different script after a GetNumbers() call e.g.
GetNumbers() -> User enters 4427 -> Load up script 4427.vgs and execute it to user
The intention is to use this for differnet marketing campaigns which are running for different clients -- we dont want one "huge" script
Thx
Adam
You can use $RV's in the goto path - so just specify the name of your new script using the Result Variable which holds the data entered in the Get Numbers module in it..
