Disconnect Tone Detection
newbie in detecting frequency needs some help here guys, I've read some entries here that you can manually get the frequency of the disconnect tone using cooledit. I downloaded the program but I'm having a hard getting the correct value using that utilities. Any help on how to get the frequency would be a great help to me. I attached my disconnect tone here if you want to detet it.
Thanks in advance.
JBL
discon_tone.zip
This disconnect tone is quite unusual.
The tones are a single frequency of 564Hz.
The cadence is:
ON for 165ms
OFF for 395ms
ON for 300ms
OFF for 270ms
I'd recommend the Dialogic TSP settings to be:
Freq 1 : 564
Freq 1 deviation : 50
Freq 2 : 0
Freq 2 deviation : 0
On time : 23
On time deviation : 10
Off time : 33
Off time deviation : 10
Repetition : 3
Thanks for the reply, I tried using that TSP already but still no luck in detecting the disconnect tone. I did try using perfect call analysis also in defining the tones using dx_blddtcad() function still the same result.
Thanks in advance,
JBL
Try changing the repetitions count down, and increasing the deviation settings until it detects the disconnect - and please let us know at what settings the disconnect tone became detected.
hi,
I can detect the disconnect tone already. this is the paremeter that works.
Freq 1 : 500
Freq 1 deviation : 100
Freq 2 : 0
On time : 23
Off time : 0
Off time deviation : 0
Repetition : 2
Is there any problem eventhough I have no value for off time and a deviation of 100?
Thanks.
JBL
By disabling the 'off' cadence while having the 'repetition set to 2 you are probably setting the card to detect on ON tone of between 260ms and 660ms - and one of the ON tones falls in this range.
If that works for you OK then you can stick with it - I'd try to experiment with using the OFF setting as well to create a ON/OFF cadence based detection - this reduces the chance of false detections.
