Pager Notification
I'm getting some succes with this new modem I just bought (External Modem Balster V92 USB). I really want this software to work. It's the best featured program I have found to date.
Problem: My voicemail boxes aren't notifying my pager. I am using the trial version.
60718 0 tapie callstate OFFERING 65861 0 4
60718 0 tapie ring 1
66687 0 tapie ring 2
66687 0 Answer the call
66687 0 lineAnswer(65861) => 65724
66687 0 tapie callstate ACCEPTED 65861 0 0
66812 0 tapi Reply 65724 0
66812 0 tapie callstate CONNECTED 65861,0,0
66812 0 WorkingModeTAPI=
66812 0 WorkingModeScript=
66812 0 TimeoutClear
66812 0 [Main] Playing
66812 0 [Main] Playing (C:\Program Files\ivg\Scripts\Custom Messages\Main.wav)
66968 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Custom Messages\Main.wav]
66968 0 TimeoutClear
66968 0 RunModule PLAY end
66968 0 wa(12063,46681200)
76218 0 tapie monitordigits 50 2
76218 0 LsPlayMsg [2]
79015 0 PlaySoundStop ok
79031 0 TimeoutClear
79031 0 [Chairs & Linens] Playing
79031 0 [Chairs & Linens] Playing (C:\Program Files\ivg\Scripts\Custom Messages\Chairs & Linens VM.wav)
79171 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\Custom Messages\Chairs & Linens VM.wav]
79171 0 TimeoutClear
79171 0 RunModule PLAY end
79171 0 wa(11786,47903100)
90984 0 Play End line[0] (id=479031)
90984 0 LsPlayMsg EV_PLAY_FINISHED
90984 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
90984 0 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
90984 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
90984 0 TimeoutClear
90984 0 [220] Playing Welcome Message
91078 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\VmbWelcomeMsgDefault.wav]
91093 0 TimeoutClear
91093 0 [220] Play welcome message
91093 0 wa(2869,49100000)
93984 0 Play End line[0] (id=491000)
93984 0 LsVmLm_PlayWelc EV_PLAY_FINISHED
94093 0 PlaySoundStart ok [C:\Program Files\ivg\system\voice\beep1.wav]
94093 0 TimeoutClear
94093 0 wa(428,49398400)
94562 0 Play End line[0] (id=493984)
94562 0 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
94640 0 RecSoundStart file[C:\Program Files\ivg\data\VmSave\220_0515101355_1_0_.wav] ok
94640 0 TimeoutSet 180 EV_TIMEOUT_RECMAXTIME
94640 0 [220] Recording Message
06640 0 LsVmLm_Rec EV_SILENCE_DETECTED
06640 0 Silence Detected
06640 0 TimeoutSet 2 EV_REC_FINISHED
11656 0 LsVmLm_Rec EV_REC_FINISHED
11656 0 TimeoutClear
11656 0 tapie monitordigits 42 2
11656 0 LsVmLm_Rec
11656 0 TimeoutSet 2 EV_REC_FINISHED
11671 0 Send pager message to phone: 4014828284
11671 0 Hanging up call...
11671 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
11671 0 PlaySoundStop ok
11671 0 fnHangupCall end
11750 0 tapie callstate DISCONNECTED 65861,1,0
11750 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
11750 0 PlaySoundStop ok
11765 0 Hanging up call...
11765 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
11765 0 PlaySoundStop ok
11765 0 fnHangupCall end
11765 0 tapie callstate IDLE 65861 0 0
11765 0 WorkingMode@Idle=
11765 0 TimeoutClear
11781 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
11781 0 tapi Reply 65707 0
11781 0 tapi Reply 65690 0
12765 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
12765 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
12765 0 Initialise telephony (due to IDLE)
12765 0 tapic lineDeallocateCall(MainCall:65861) 0
12812 0 Waiting for a call...
12812 0 hLine=65673
12828 0 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
13671 0 Loading from C:\Program Files\ivg\data\DialListNew.txt
13671 0 Loaded 0 entries.
18296 0 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
What version of VoiceGuide are you using? I just tried it in v4.9.0 and it works fine :
65656 7 [0001] Playing Welcome Message
65734 7 PlaySoundStart ok [C:\Projects\vg32\system\voicedlgc\VmbWelcomeMsgDefault.wav]
65734 7 [0001] Play welcome message
68640 7 wb(16567100)
68703 7 Play End line[7] (id=165671)
68703 7 LsVmLm_PlayWelc EV_PLAY_FINISHED
68765 7 PlaySoundStart ok [C:\Projects\vg32\system\voicedlgc\beep1.wav]
68968 7 wb(16871800)
69031 7 Play End line[7] (id=168718)
69031 7 LsVmLm_PlayWelc_Beep EV_PLAY_FINISHED
69046 7 RecSoundStart file[C:\Projects\vg32\data\VmSave\0001_0516010807_1_7_.wav] ok
69046 7 Voicemail_MaxRecLength=15.
69062 7 [0001] Recording Message
74796 7 tapie monitortone 1
75125 7 LsVmLm_Rec EV_SILENCE_DETECTED
75125 7 Silence Detected
75171 7 LsVmLm_Rec EV_REC_FINISHED
75187 7 Send pager message to phone: 1111
75187 7 HangupCall called from [srvm1]
75187 7 Hanging up call...
75203 7 PlaySoundStop ok
75203 7 fnHangupCall end
75250 7 tapie linedevstate 2048 0 0
75250 7 tapie callstate IDLE 66509 0 0
75265 7 WorkingMode@Idle=
75312 7 set EV_TIMEOUT_TIMETOREINITLINE 2
75328 7 tapi Reply 66134 0
76031 0 Loading from C:\Projects\vg32\data\DialListNew.txt
76046 0 Loaded 1 entries.
76046 0 Ready To DialOut : 1 (out of 1)
76312 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
76312 7 ReinitTelephony due to IDLE start
76328 7 tapic lineDeallocateCall(MainCall:66509) 0
76484 7 lineOpen(7) => 0
76484 7 Waiting for a call...
76484 7 lineOpen(7)LineHandle=66083
78062 0 Ready To DialOut : 1 (out of 1)
80078 0 Ready To DialOut : 1 (out of 1)
82093 0 Ready To DialOut : 1 (out of 1)
84109 0 Ready To DialOut : 1 (out of 1)
86140 0 Ready To DialOut : 1 (out of 1)
(I did not have any lines enabled for outbound dialing, but if any were then a call to a number "1111" would have been placed...)
What is the playback and record sound quality of your "External Modem Balster V92 USB" like?
I am using Interactive Voice Guide 4.8.46 (trial version). I will try uninstallling and installing the Voice Guide from the Katalina site.
As to the second question about the sound quality on my modem, I don't know. Where can I get that information ?
When you listen to the messages played by that modem when you call the system - so they sound good? What about the quality of the recorded voicemail message - when you play them back do they sound clear?
They could sound a little better, but they are not bad. I would say that it sounds similar to or slightly better than a recording on a typical answering machine.
