Results Variable And Db Query
I am using a query and usually the result should be at least 100 lines by 6 columns, i need to copy this data into word so i will be able to fax a properly formatted page.
My question is quite basic:
How do i move on to the next line? if i'm using a result variable to access the data like this: $RV[ModuleName_$RV[row]_1] how do i increment the RV, (i know that i can do it in Evaluate expression but then it means i need to get out of the script each iteration which is cumbersomeh).
Thanks.
I might have not explained myself properly so here's part of the script:
for counter=1 to $RV[GetResults_RowCount]
myTable.cell(RowNum,ColNum).range.Insertafter($RV[GetResults_$RV[RowRes]_1])
myTable.rows.Add
RowNum=RowNum+1
counter=counter+1
next
I've defined RowRes in a previous module to 1.
So how do I increment $RV[RowRes] from 1 to 2 to 3 etc.?
I've manage to get the value but that doesn't help me, i've tried to set it but either i'm using a wrong syntax or it's not possible and the value stays 1.
Thanks.
The way that Result Variables work when used within a "Run VBScript" module is that they get replaced by their current value and then the VBScript is ran just like any other VBScript...
Have a look at this approach:
for counter = 1 to $RV[GetResults_RowCount]
 sRvToRetreive = "RV[GetResults_" & counter & "_1]"
 sReturnValue = vg.RvGet($RV_LINEID, sRvToRetreive)
 myTable.cell(RowNum,ColNum).range.Insertafter(sReturnValue )
 myTable.rows.Add
 RowNum=RowNum+1
next
set vg = Nothing
I assume that ColNum was set previously...
