Adam Report post Posted 03/20/2005 02:07 AM Does Voiceguide support dual processor computers? Adam Share this post Link to post
SupportTeam Report post Posted 03/20/2005 02:33 AM Yes. The various processes started by VoiceGuide will be load shared across multiple CPUs. There is only any benefit looking at multiple-CPU system if you are intending to run 120+ lines on the machine... Below 120 lines a single high end CPU (2GHz+) is more then enough. (unless you intend to run a database server and/or other tasks on the machine as well) Share this post Link to post
