Problem With Say Number Xx.zz
I'm having problem with the say number module, i'm using a live stock query to say the stocks value which can be with decimal like 27.5 i want the say number to say the number as "twenty seven point five" it's always saying "twenty seven" and ignores the fractions.!!
i tried the say number as options but still the same!?
please help
The Say Number does handle decimals.
Just verified this on our test system here in the lab and it works fine...
If you still have problems could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
You can enable the automatic saving of the logs to files in \log\ directory as well.
