Will Not Play File
I cannot get the credit card file to play when I phone into the system. It was working but now it is not. Why???
See log of events:
195104.51 6 linedevstate 2048 0 0
195104.51 6 callstate OFFERING 65945 0 4
195104.55 6 Lev_CallerID [4385891,CLYMANS J & E,]
195104.58 6 callinfo CALLEDID
195104.58 6 callinfo ORIGIN
195104.58 6 ring 0
195104.80 0 dial start any summary:|5:dok=0|6:hc>0|7:dok=0|8:dok=0|
195110.52 6 ring 2
195110.52 6 rv clear
195110.53 6 Answer the call at 3/20/2005 7:51:10 PM
195110.53 6 lineAnswer(65945) => 65928
195111.09 6 callstate CONNECTED 65945 1 0
195111.09 6 callstate CONNECTED 65945,1,0
195111.09 6 WorkingModeTAPI@Connected=
195111.09 6 WorkingModeScript@Connected=
195111.12 6 Inband detection not enabled
195111.13 6 StartLoadedVgs at 3/20/2005 7:51:11 PM, v5.2.3063
195111.13 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}
195111.13 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment}
195111.13 6 rv add [$RV_STARTTIME]{3/20/2005 7:51:11 PM}
195111.13 6 rv add [$RV_DEVICEID]{6}
195111.15 6 rv add [$RV_CIDNAME]{CLYMANS J & E}
195111.15 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
195111.16 6 rv add [$RV_CIDNUMBER]{4385891}
195111.16 6 tapi Reply (LineEvReply) ok 65928 0
195111.16 6 callinfo MONITORMODES
195111.16 6 timer clear
195111.16 6 [Get Client ID] Number Input
195111.17 6 [Get Client ID] Playing (PayGetId.wav)
195111.19 6 play set playid=533845
195111.20 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav]
195111.20 6 path {WAVERR_BADFORMAT} not found
195111.20 6 play set playid=533845
195111.22 6 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32,play pss EnsureWaveOutIsOpenAndReady=>play waveOutOpen mapped failed WAVERR_BADFORMAT] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
195111.22 6 For Dialogic use: PCM 11Khz 8bit Mono
195111.23 6 rv add [Hangup Time]{3/20/2005 7:51:11 PM}
195111.23 6 Hanging up call... [srlib PlaySoundStart]
195111.23 6 RecSoundStop ok
195111.23 6 PlaySoundStop err=0
195111.24 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
195111.26 6 fnHangupCall end
195111.26 6 play end current play (playid=0)
195111.27 6 ScriptEventCode 8001 iLineState=900
195111.27 6 LsAwaitingCalls EV_PLAY_FINISHED
195111.27 6 play end current play (playid=0)
195113.12 6 linedevstate 2048 0 0
195113.13 6 callstate IDLE 65945 0 0
195113.13 6 WorkingMode@Idle=
195113.14 6 timer clear
195113.15 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
195113.16 6 tapi Reply (LineEvReply) ok 65911 0
195114.09 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
195114.09 6 ScriptEventCode 9008 iLineState=900
195114.10 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
195114.10 6 ReinitTelephony due to IDLE
195114.11 6 tapic lineDeallocateCall(MainCall:65945) 0
195114.25 6 lineOpen(6)=>
195114.26 6 Waiting for a call...
195114.26 6 LineHandle=65894
195114.27 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
195114.82 0 dial start any summary:|5:dok=0|6:rdy=0|7:dok=0|8:dok=0|
195117.27 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
195117.27 6 ScriptEventCode 9013 iLineState=900
195117.82 0 dial start any summary:|5:dok=0|6:dok=0|7:dok=0|8:dok=0|
Can you please advise me as to what I must do to fix this problem?
Thanks in advance.
My email is testpilot@sympatico.ca
The error is: WAVERR_BADFORMAT
Are yon using Voice modem or a Dialogic card?
Did you select the right option (Modem/Dialogic) when installing the software?
Can you check what format the sound file "C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayGetId.wav" is in?
