Hang Up
Hello,
My VBScript wasn't working on my labtop computer (development computer). I found out that it was because my labtop was running on XP home edition. So, I loaded XP Professional and the problem was solved.
I am now facing another problem, and that problem is "Global End-of-Call DTMF (D)". For some reason, this problem only happens to one of my sound files, "SayCurrentAmountBy Farsi2," my other play sound files are working fine. also I don't have this problem in my production computer which has win 2000.
please see my log file bellow.
181053.45 0 [sayCurrentAmountByFarsi2] Planing (f3.wav, f5.wav, f5.wav, f5.wav, f0.wav, f4.wav, fdecimal.wav, f5.wav)
181053.48 0 play set playid=530035
181053.63 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\f3.wav,C:\Program Files\VoiceGuide\system\voice\f5.wav,C:\Program Files\VoiceGuide\system\voice\f5.wav,C:\Program Files\VoiceGuide\system\voice\f5.wav,C:\Program Files\VoiceGuide\system\voice\f0.wav,C:\Program Files\VoiceGuide\system\voice\f4.wav,C:\Program Files\VoiceGuide\system\voice\fdecimal.wav,C:\Program Files\VoiceGuide\system\voice\f5.wav]
181053.66 0 timer clear
181053.68 0 RunModule PLAY end
181053.73 0 wa(3700,53003505)
181057.37 0 play end current play (playid=530035)
181057.41 0 ScriptEventCode 8001 iLineState=1100
181057.45 0 LsPlayMsg EV_PLAY_FINISHED
181057.49 0 timer set 10 EV_TIMEOUT_HANGUP
181057.53 0 timer set 0 EV_TIMEOUT_GOTOMODULE
181057.57 0 ScriptEventCode 9002 iLineState=1101
181057.61 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
181057.65 0 timer clear
181057.69 0 [sayCurrentAmountByFarsi3] Playing
181057.72 0 rv replace start: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\$RV[Language]\$RV[CurrencyType]$RV[CurrencyType].wav]
181057.75 0 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainManuWithOutCC\}[scriptPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainManuWithOutCC}[$RV_STARTTIME]{3/20/2005 6:09:05 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{HO WAIYI}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{4082636596}[selectLanguage]{2}[selectLanguage_PathTaken]{matc
ed}[Language_Input]{2}[Language]{2}[scriptEnd_Time]{3/20/2005 6:09:34 PM}[scriptEnd_Goto_Script]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\Whitdraw\Withdraw.vgs}[scriptEnd_Goto_Module]{retrysetCC1}[scriptStart_Time]{3/20/2005 6:09:34 PM}[scriptStart_CalledFrom_Script]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\MainManuWithOutCC\MainManuWithOutCC.vgs}[scriptStart_CalledFrom_Module]{UseCNumOrBuyNew}[scri
tsPath]{C:\Program Files\ivg\Scripts\PBPScript\MCAC\starting scrip\Whitdraw\}[retrysetCC1]{2}[retrysetCC1_Input]{0}[retrysetCC1]{0}[retrycount]{0}[GetC
um]{8002}[GetCNum_PathTaken]{success}[lookForCNum_RowCount]{1}[lookForCNum_1_1]{
000}[lookforCNumResult_Input]{4000}[lookforCNumResult]{4000}[CardFound?_Input]{4000 = 101}[CardFound?]{False}[ReportBalance_RowCount]{1}[ReportBalance_1_1]{390}[balanceResult_Input]
390}[balanceResult]{390}[EvaluatLanguage1_Input]{2}[EvaluatLanguage1]{2}[WavsToP
ay]{f3.wav,fhundred.wav,f90.wav,fdollars.wav,fand.wav,f0.wav,fcents.wav}[confirm
mt2.wav_152]{2}[retrysetAgancy_Input]{0}[retrysetAgancy]{0}[retrycount]{0}[POSCo
eNum]{123456}[POSCodeNum_PathTaken]{success}[lookForAgancy_RowCount]{1}[lookForA
ancy_1_1]{123456}[lookforAgancyResult_Input]{123456}[lookforAgancyResult]{123456
[GetAmt]{10}[GetAmt_PathTaken]{success}[EvalLanguge_Input]{2}[EvalLanguge]{2}[Wa
sToPlay]{f10.wav,fdollars.wav,fand.wav,f0.wav,fcents.wav}[confirmAmt2.wav]{1}[Lo
kForBalance_RowCount]{1}[LookForBalance_1_1]{390}[LookForBalanceResult_Input]{39
}[LookForBalanceResult]{390}[CalculatBalance_Input]{390 - 10}[CalculatBalance]{380}[NewBalance_Input]{"380"}[NewBalance]{380}[EfficientBalance?_Input]{10 <= 390}[EfficientBalance?]{True}[lookPercentAndSaleType_RowCount]{1}[lookPercentAndSaleType_1_1]{.03}[loo
PercentAndSaleType_2_1]{+}[PercentRate_Input]{.03}[PercentRate]{0.03}[saleType_I
put]{+}[saleType]{+}[LookForCurrencyRate_RowCount]{1}[LookForCurrencyRate_1_1]{8
5}[CurrencyRateResult_Input]{885}[CurrencyRateResult]{885}[ConvertDollerToCurren
y_Input]{(390+(390*0.03))*885}[ConvertDollerToCurrency]{355504.5}[lookForCurrenc
Type_RowCount]{1}[lookForCurrencyType_1_1]{2}[CurrencyType_Input]{2}[CurrencyTyp
]{2}[EvaluatLanguage44_Input]{2}[EvaluatLanguage44]{2}[WavsToPlay]{f3.wav, f5.wav, f5.wav, f5.wav, f0.wav, f4.wav, fdecimal.wav, f5.wav}
181057.79 0 rv replace end: [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\2\22.wav]
181057.82 0 [sayCurrentAmountByFarsi3] Playing (C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\2\22.wav)
181057.85 0 play set playid=534411
181058.02 0 PlaySoundStart ok [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\2\22.wav]
181058.05 0 timer clear
181058.08 0 RunModule PLAY end
181058.11 0 wa(7441,53441100)
181058.43 0 dtmf D (66252,68,2)
181058.46 0 ScriptEventCode 68 iLineState=1100
181058.49 0 rv add [Hangup Time]{3/20/2005 6:10:58 PM}
181058.52 0 Hanging up call... [Global End-of-Call DTMF (D)]
181058.56 0 RecSoundStop ok
181105.54 0 PlaySoundStop err=0
181105.55 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
181105.55 0 fnHangupCall end
181105.72 0 callstate DISCONNECTED 66252 1 0
181105.76 0 ScriptEventCode 9250 iLineState=900
181105.79 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
181105.83 0 rv add [Hangup Time]{3/20/2005 6:11:05 PM}
181105.86 0 Hanging up call...
181105.90 0 RecSoundStop ok
181105.93 0 PlaySoundStop err=0
181105.96 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
181105.99 0 fnHangupCall end
181106.02 0 callstate IDLE 66252 0 0
181106.05 0 WorkingMode@Idle=
181106.08 0 timer clear
181106.11 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
181106.14 0 tapi Reply (LineEvReply) ok 66218 0
181106.17 0 tapi Reply (LineEvReply) ok 66201 0
181107.11 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
181107.13 0 ScriptEventCode 9008 iLineState=900
181107.18 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
181107.20 0 ReinitTelephony due to IDLE
181107.24 0 tapic lineDeallocateCall(MainCall:66252) 0
181107.41 0 lineOpen(0)=>
181107.45 0 Waiting for a call...
181107.48 0 LineHandle=66184
181107.52 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
181107.66 0 dial start any summary:|0:rdy=0|
181110.55 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
181110.58 0 ScriptEventCode 9013 iLineState=900
181110.71 0 dial start any summary:|0:idx=0|
I take it that you are using a Voice Modem?
Many modems falsely detect tones while playing sound files....
The usual options are to change the sound file, change the modem or best yet start using a Dialogic card.
I am using dialogic board D/160SC-LS.
I could successfully transfer the call, but I still have problem with path. the transfer call doesn’t goes trough the success or fail path.
How can I solve this problem?
