Guest Guest_Jack Report post Posted 03/22/2005 03:02 PM Is it possible to execute TTS from within a VB Script module? If so, how? Thanks, Jack Share this post Link to post
SupportTeam Report post Posted 03/22/2005 11:17 PM Not direct from VBScript module, but you can assign the text to be spoken to a Result Variable within the Run VBScript module and then TTS speak the contents of that variable in the following Play module. Share this post Link to post
