Tts In Vb Script Module?
Is it possible to execute TTS from within a VB Script module? If so, how?
Thanks,
Jack
Not direct from VBScript module, but you can assign the text to be spoken to a Result Variable within the Run VBScript module and then TTS speak the contents of that variable in the following Play module.
