Vb.net App Sample
This application is a small form that pops on the server side when a call comes in from a VG Script. Just copy and paste the following the code into a new VB.NET solution:
Public Class Form1
   Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
   Public Sub New()
       MyBase.New()
       'This call is required by the Windows Form Designer.
       InitializeComponent()
       'Add any initialization after the InitializeComponent() call
   End Sub
   'Form overrides dispose to clean up the component list.
   Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
       If disposing Then
           If Not (components Is Nothing) Then
               components.Dispose()
           End If
       End If
       MyBase.Dispose(disposing)
   End Sub
   'Required by the Windows Form Designer
   Private components As System.ComponentModel.IContainer
   'NOTE: The following procedure is required by the Windows Form Designer
   'It can be modified using the Windows Form Designer.
   'Do not modify it using the code editor.
   Friend WithEvents TextBox1 As System.Windows.Forms.TextBox
   Friend WithEvents Label1 As System.Windows.Forms.Label
   Friend WithEvents Label2 As System.Windows.Forms.Label
   Friend WithEvents TextBox2 As System.Windows.Forms.TextBox
   Friend WithEvents Label3 As System.Windows.Forms.Label
   Friend WithEvents TextBox3 As System.Windows.Forms.TextBox
   Friend WithEvents Label4 As System.Windows.Forms.Label
   Friend WithEvents TextBox4 As System.Windows.Forms.TextBox
   <System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
       Me.TextBox1 = New System.Windows.Forms.TextBox
       Me.Label1 = New System.Windows.Forms.Label
       Me.Label2 = New System.Windows.Forms.Label
       Me.TextBox2 = New System.Windows.Forms.TextBox
       Me.Label3 = New System.Windows.Forms.Label
       Me.TextBox3 = New System.Windows.Forms.TextBox
       Me.Label4 = New System.Windows.Forms.Label
       Me.TextBox4 = New System.Windows.Forms.TextBox
       Me.SuspendLayout()
       'TextBox1
       Me.TextBox1.Location = New System.Drawing.Point(16, 32)
       Me.TextBox1.Name = "TextBox1"
       Me.TextBox1.Size = New System.Drawing.Size(328, 20)
       Me.TextBox1.TabIndex = 0
       Me.TextBox1.Text = ""
       'Label1
       Me.Label1.Location = New System.Drawing.Point(16, 16)
       Me.Label1.Name = "Label1"
       Me.Label1.TabIndex = 1
       Me.Label1.Text = "Extension dialed :"
       'Label2
       Me.Label2.Location = New System.Drawing.Point(16, 80)
       Me.Label2.Name = "Label2"
       Me.Label2.TabIndex = 2
       Me.Label2.Text = "Line ID"
       'TextBox2
       Me.TextBox2.Location = New System.Drawing.Point(16, 96)
       Me.TextBox2.Name = "TextBox2"
       Me.TextBox2.Size = New System.Drawing.Size(328, 20)
       Me.TextBox2.TabIndex = 3
       Me.TextBox2.Text = ""
       'Label3
       Me.Label3.Location = New System.Drawing.Point(16, 144)
       Me.Label3.Name = "Label3"
       Me.Label3.TabIndex = 4
       Me.Label3.Text = "Caller ID"
       'TextBox3
       Me.TextBox3.Location = New System.Drawing.Point(16, 160)
       Me.TextBox3.Name = "TextBox3"
       Me.TextBox3.Size = New System.Drawing.Size(328, 20)
       Me.TextBox3.TabIndex = 5
       Me.TextBox3.Text = ""
       'Label4
       Me.Label4.Location = New System.Drawing.Point(16, 208)
       Me.Label4.Name = "Label4"
       Me.Label4.TabIndex = 6
       Me.Label4.Text = "Caller Name"
       'TextBox4
       Me.TextBox4.Location = New System.Drawing.Point(16, 224)
       Me.TextBox4.Name = "TextBox4"
       Me.TextBox4.Size = New System.Drawing.Size(328, 20)
       Me.TextBox4.TabIndex = 7
       Me.TextBox4.Text = ""
       'Form1
       Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
       Me.ClientSize = New System.Drawing.Size(360, 278)
       Me.Controls.Add(Me.TextBox4)
       Me.Controls.Add(Me.Label4)
       Me.Controls.Add(Me.TextBox3)
       Me.Controls.Add(Me.Label3)
       Me.Controls.Add(Me.TextBox2)
       Me.Controls.Add(Me.Label2)
       Me.Controls.Add(Me.TextBox1)
       Me.Controls.Add(Me.Label1)
       Me.Name = "Form1"
       Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
       Me.Text = "Form1"
       Me.ResumeLayout(False)
   End Sub
#End Region
   Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
       'Call the function to capture the digits
       CallArgs()
   End Sub
   Private Sub CallArgs()
       Dim Args() As String = Environment.GetCommandLineArgs
       If Args.GetUpperBound(0) > 0 Then 'remember to test the size of the array
           TextBox1.Text = Args(1)
           TextBox2.Text = Args(2)
           If Args(3) = "" Then
               TextBox3.Text = "UNKNOWN CALLER"
           Else
               TextBox3.Text = Args(3)
           End If
           If Args(4) = "" Then
               TextBox4.Text = "UNKNOWN CALLER"
           Else
               TextBox4.Text = Args(4)
           End If
       End If
   End Sub
End Class
Now, to get the VG to pop it, do the following: Use the attached VGS file. Record a wav to prompt the extension to be dialed. And test from there.
Just a little something to help out. Cheers!!
No .VGS file was attached... any chance you could try attaching it again?
