Trouble Writing Data To Access Database
I am writing the results of each call to an Access Database table called call record. This had been working successfully. However, I wanted to log wav file play modules and track which modules timed out. I upgraded versions, but now my Insert Into statement isn't executing correctly. I get the following error message. Any suggestions would be appreciated.
100253.68 10 timer clear
100253.68 10 [updateCallRecord] DB Query
100253.70 10 db Jet mode used (To use ODBC mode specify ODBC Connect string)
100253.89 10 rv replace start (strlen>500)
100253.90 10 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{J:\IVR\VoiceGuide\AspirinandDiabetes\Scripts\}[scriptPath]{J:\IVR\VoiceGuide\AspirinandDiabetes\Scripts}[$RV_STARTTIME]{3/28/2005 9:59:37 AM}[$RV_DEVICEID]{10}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[setIncomingCall_Input]{1}[setIncomingCall]{1}[isIncomingCal
]{1}[ClearCounter_Input]{0}[ClearCounter]{0}[hrNCounter]{0}[PREHRN2]{555555555}[
etPatientInfo_RowCount]{1}[GetPatientInfo_1_1]{Steve}[GetPatientInfo_2_1]{Bensen
[GetPatientInfo_3_1]{555555555}[GetPatientInfo_4_1]{555}[scriptEnd_Time]{3/28/2005 9:59:57 AM}[scriptEnd_Goto_Script]{\\Rmregfile004\Research\IVR\VoiceGuide\AspirinandDiabetes\Scripts\AspirinandDiabetes.vgs}[scriptEnd_Goto_Module]{Intro1}[scriptStart_Time]{3/28/2005 9:59:57 AM}[scriptStart_CalledFrom_Script]{J:\IVR\VoiceGuide\AspirinandDiabetes\Scripts\IncomingInitCallValidate2HRN.vgs}[scriptStart_CalledFrom_Module]{GetPatient
nfo}[scriptsPath]{\\Rmregfile004\Research\IVR\VoiceGuide\AspirinandDiabetes\Scripts\}[intro1]{timeout}[GetNowValue_Input]{Now}[GetNowValue]{3/28/2005 10:00:28 AM}[NewNowValue]{3/28/2005 10:00:28 AM}[Activity]{-1}[DaysofActivity]{0}[TotalTime]{0}[Aspirin]{-1}[ReasonNoAspirin]{-1}[Allergic]{-1}[bloodThinner]{-1}[OtherProblems]{-1}[ReasonsNoAspirin]{-1}[Forget]{-1}[TooManyMeds]{-1}[WontBenefit]{-1}[sideEffects]{-1}[MoreInfo]{-1}[Congratulations]{-1}[strategies]{-1}[Concerns]{-1}[Recommendation]{-1}[GoodJob]{-1}[HeartTrouble]{-1}[ChestPains]{-1}[Dizzy]{-1}[HighBP]{-1}[JointArthritis]{-1}[PhysicalReason]{-1}[Over65]{-1}[TalktoDr]{-1}[safelyExercise]{-1}[sGrecs]{-1}[GetHurt]{-1}[DontEnjoy]{-1}[NoTime]{-1}[NoPlace]{-1}[FindingTime]{-1}[ExerciseSafe]{-1}[ExCount]{0}[NoBarriers]{-1}[ModerateOK]{-1}[ThankYou]{0}[Re-SetRVs_ResultReturn]{success}[Activity]{1}[DaysofActivity]{3}[TotalTime]{30}[Asp
rin]{2}[ReasonNoAsprin]{2}[Allergic]{2}[bloodThinner]{2}[OtherProblems]{2}[Medic
lConditions_Input]{(2 = 2) AND (2 = 2) AND (2 = 2)}[MedicalConditions]{True}[medicalconditionspath]{True}[RecommendAspirin]{2}[R
asonsnoAspirin]{timeout}[Forget]{2}[TooManyMeds]{2}[WontBenefit]{2}[sideEffects]
2}[MoreInfo]{2}[EvaluateforStrategies_Input]{(2 = 2) AND (2 = 2)}[EvaluateforStrategies]{True}[EvalStrategies]{True}[EvaluateforConcerns_Input
{(2 = 2) AND (2 = 2) AND (2 = 2)}[EvaluateforConcerns]{True}[EvalConcerns]{True}[EvalNoAspirinBarriers_Input]{
True = True) AND (True = True)}[EvalNoAspirinBarriers]{True}[EvalnoABarrier]{True}[Recommendation]{timeou
}[ThankYou]{2}[ThankYou_PathTaken]{success}
100253.91 10 db About to execute a Modify type operation [iNSERT INTO CallRecord (StudyID, CallDateTime, IsIncomingCall, Activity, DaysofActivity, TotalTime, Aspirin, ReasonNoAspirin, Allergic, BloodThinner, OtherProblems, ReasonsNoAspirin, Forget, TooManyMeds, WontBenefit, SideEffects, MoreInfo, Congratulations, Strategies, Concerns, Recommendation, GoodJob, HeartTrouble, ChestPains, Dizzy, HighBP, JointArthritis, PhysicalReason, Over65, TalktoDr, SafelyExercise, SGrecs, GetHurt, DontEnjoy, NoTime, NoPlace, FindingTime, ExerciseSafe, ExCount, NoBarriers, ModerateOK, ThankYou) VALUES (555, #3/28/2005 10:00:28 AM#, 1, 1, 3, 30, 2, -1, 2, 2, 2, timeout, 2, 2, 2, 2, 2, -1, -1, -1, timeout, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, 0, -1, -1, 2);]
100253.98 10 ERROR 5.2.3072 DB Execute: 3061,Too few parameters. Expected 1.
100253.99 10 rv lg add [updateCallRecord_RowCount]{0}
100254.02 10 db DBEngine.Error 3061:Too few parameters. Expected 1.:DAO.Database
100254.05 10 path {0} not found
100254.07 10 path {} not found
100254.09 10 rv lg add [Hangup Time]{3/28/2005 10:02:54 AM}
100254.09 10 Hanging up call... [GoNextVgm_Boolean fail]
100254.10 10 RecSoundStop ok
The problem does seem to be that the SQL statement fails to be correctly interpreted by the database.
I'd try debugging the SQL statement by first simplifying it and then gradually expanding it to see at which stage it fails.
I pasted the sequel statement into an Access query and ran it. Even though the access fields are text fields. The program is hanging on the RV's with 'timeout' as the datastring. When I put single quotes around the word time out each time it occurs, the SQL executes correctly. Any suggestions on how to program voice guide so I can take the RV with "timeout" as the result and insert that into a call record? Steve
One approach would be to set up all the database fields as "text" instead of "number" and then just put quotes around all of the RVs specified in the query.
Another way would be to point the timeout path in each input module to an Evaluate Expression module which resets the RV to a different value.
