Guest Guest_badi Report post Posted 04/06/2005 12:16 AM hi i have VG v5.2.3028. when i enter the voice mail system to retrieve the messages & select the choice with give me the time & date & CID of the message wich retrieved, the order is not good for another language & i need to change the order of the saying. the defult order is (eg: 4th march, two fifty five pm) i need (eg: 4th march the hour is two and five fifty minuts pm) how i make this change? please telllllllll meeeeeeeee. thanx. Share this post Link to post
SupportTeam Report post Posted 04/06/2005 12:36 AM From http://www.voiceguide.com/vghelp/html/modSayNumber.htm : Quote Need to change the way Say Number module speaks Amounts/Dates ? Users can edit the way in which the numbers are spoken, or even add their own Say Number functions by editing the file: lib_num2wav.vbs located in VoiceGuide's \system\vbs\ subdirectory. This is useful if it is required to say numbers/amounts in a language other then English. Please read the lib_num2wav.vbs file for more information. You will then just need to change the voicemail script (see VoiceGuide's \system\vm\ subdirectory) to use the new 'say time/date' function you created. Share this post Link to post
