Installing D/4pci
hi, i have purchased d/4pci card and have downloaded all the necessary drivers including SR5.1.1, SP1, globalcall , and have installed them in the proper sequence in windows2000, but still in the device manager ,i see a yellow sign over Dialogic card type? and also when i run the DCM, i get the error of "unable to start the service"?
If the Dialogic DCM cannot start the card they you should speak with the Dialogic distributor from where you've purchased the card.
