Script Stop After Playing A Tts Wave File
Dear support,
I use Voice Guide version 5.2.3053 and TTS.
Sometimes scripts stops just after playing a generated TTS wave file.
Here is an example :
140907.70 10 tts generate start[saisie rétroactive d'information patient]
140907.70 10 tts generate wait
140907.70 10 RunModule PLAY end
140907.80 10 tts generate finish. lineCallState=CONNECTED
140907.80 10 [ML_MP_M4_DitTitre] Playing (C:\Program Files\VoiceGuide\data\tts_10_3.wav)
140907.80 10 play set playid=-586859
140907.81 10 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts_10_3.wav]
140907.81 10 timer clear
140907.81 10 wa(2717,-58685900)
140908.11 0 dial start any summary:|10:hc>0|11:dok=0|12:dok=0|13:dok=0|
140909.11 0 dial start any summary:|10:hc>0|11:dok=0|12:dok=0|13:dok=0|
140910.11 0 dial start any summary:|10:hc>0|11:dok=0|12:dok=0|13:dok=0|
140910.55 10 play end current play (playid=-586859)
140910.55 10 ScriptEventCode 8001 iLineState=1100
140910.55 10 LsPlayMsg EV_PLAY_FINISHED
140910.55 10 ignoring EV_PLAY_FINISHED as EV_TIMEOUT_REPLAYMSG set in timers - looks like we are replaying TTS sound file
After this the script stops.
This problem is not systematic but happens sometimes.
Do you have an idea of what can cause this problem.
Thank you for your answer.
Best regards
Pierre Métrailler
