Guest mhsamei Report post Posted 04/18/2005 04:48 PM Hi Dear. I want to set Correct The windows time from get number madule. How can run Date and Time Properties in Windows ans send the Secound Minute & Hour and close the program? Share this post Link to post
CSI Report post Posted 04/18/2005 05:55 PM I've not tried it but you should be able to use the Run module to run the command line utility to set the time. cmd /c time $RV[inputhour]:$rv[inputminute] /c is the command line switch to run the command and then terminate the window. Share this post Link to post
