Guest Guest_vinesh Report post Posted 04/19/2005 08:15 AM hi there, does anyone have an example to trap a database connection errors on a vbs module so that i can send an email or something to inform me that the database is down. Share this post Link to post
vinesh Report post Posted 04/19/2005 08:33 AM sorry it wasn't a vbs module, its a database connection module, how do you trap errors on the database module, e.g. if a database server goes down, how do i trap those errors ? [checkCLI] Type=Database Query DispSize=69 Txt=Check CLI DbDatabase=ClientDatabase DbUser= DbConnectString=odbc;uid=UserName;pwd=Password DbSql=SELECT TOP 1 * FROM tblClients Where ClientID = '1234567890' on {success} goto [setCount1] on {fail} goto [NonRegisteredUser] on {timeout 10} goto [DatabaseTimeout] Share this post Link to post
SupportTeam Report post Posted 04/19/2005 11:34 AM If a database goes down then you would usually get the query timing out... I'd suggest using the timeout path as you are already. If you find that you are having an error returned instead then please post a copy of VoiceGuide's Debug Printout which captures the problem. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well.) Share this post Link to post
