tommie Report post Posted 04/21/2005 01:53 PM Dear, I have a problem with transfering people to an internal line (548). I use a dialogic D/PCIU card and the PBX announced transfer. What happens is that voiceguide calls the 548 but drops the caller on the line immediatly when he chooses the option to get transfered to a person. The person on 548 gets a message to accept the call... But the person who called has already dropped by voiceguide. I hope you can help me solving this problem... Here is the log... 155218,65 5 linedevstate 2048 0 0 155218,65 5 callstate OFFERING 65929 0 4 155218,65 5 callinfo CALLEDID 155218,66 5 callinfo ORIGIN 155218,66 5 ring 0 155218,86 0 dial start any summary:|5:hc>0|6:idx=0| 155224,83 5 ring 2 155224,83 5 rv clear 155224,83 5 No old processes from last call (could not obtain handle) 1904, 0 155224,83 5 Answer the call at 21/04/2005 15:52:24 155224,86 5 lineAnswer(65929) => 65912 155225,44 5 callstate CONNECTED 65929 1 0 155225,45 5 callstate CONNECTED 65929,1,0 155225,45 5 WorkingModeTAPI@Connected= 155225,45 5 WorkingModeScript@Connected= 155225,48 5 Inband detection not enabled 155225,48 5 StartLoadedVgs at 21/04/2005 15:52:25, v5.2.3063 155225,48 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\} 155225,48 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts} 155225,48 5 rv add [$RV_STARTTIME]{21/04/2005 15:52:25} 155225,48 5 rv add [$RV_DEVICEID]{5} 155225,48 5 rv add [$RV_CIDNAME]{} 155225,48 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 155225,48 5 rv add [$RV_CIDNUMBER]{} 155225,48 5 tapi Reply (LineEvReply) ok 65912 0 155225,53 5 timer clear 155225,54 5 [Welkom@yora] Playing 155225,55 5 [Welkom@yora] Playing (N:\Telefooncentrale\welkom bij yora.wav) 155225,56 5 play set playid=51242 155225,62 5 PlaySoundStart ok [N:\Telefooncentrale\welkom bij yora.wav] 155225,62 5 timer clear 155225,62 5 RunModule PLAY end 155225,63 5 wa(5507,5124200) 155225,63 5 callinfo MONITORMODES 155225,63 5 callinfo MONITORMODES 155231,01 5 dtmf 3 (65929,51,2) 155231,01 5 ScriptEventCode 51 iLineState=1100 155231,01 5 LsPlayMsg 3 155231,11 5 PlaySoundStop err=0 155231,11 5 rv add [Welkom@yora]{3} 155231,12 5 timer clear 155231,12 5 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER 155231,53 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 155231,53 5 ScriptEventCode 9012 iLineState=1900 155231,53 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 155231,53 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 155231,53 5 [reclame@yora] Announced Transfer to 548 (Generate) 155231,57 5 tapic lineGenerateDigits(65929,!,100) => 0 155232,29 5 generate LINEGENERATETERM_DONE 155232,31 5 timer set 1 EV_TAPI_GENERATE 155233,21 5 timer fired EV_TAPI_GENERATE 155233,21 5 ScriptEventCode 9602 iLineState=1900 155233,21 5 LsXferStart EV_TAPI_GENERATE 155233,21 5 timer set 1 EV_HOOKFLASHFINISHED 155234,21 5 timer fired EV_HOOKFLASHFINISHED 155234,21 5 ScriptEventCode 9200 iLineState=1905 155234,21 5 LsXferPlayVts EV_HOOKFLASHFINISHED 155234,30 5 tapic lineGenerateDigits(65929,548,100) => 0 155234,80 5 generate LINEGENERATETERM_DONE 155234,82 5 timer set 1 EV_TAPI_GENERATE 155235,80 5 timer fired EV_TAPI_GENERATE 155235,80 5 ScriptEventCode 9602 iLineState=1905 155235,80 5 LsXferPlayVts EV_TAPI_GENERATE 155235,80 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 155235,81 5 sVbsFunctionToUse=Digits 155235,94 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 155235,00 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 155236,01 5 play set playid=61687 155236,06 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 155236,06 5 timer clear 155236,07 5 wa(6941,6168701) 155236,07 5 callinfo MONITORMODES 155243,06 5 wb(6168701) 155243,11 5 play end current play (playid=61687) 155243,11 5 ScriptEventCode 8001 iLineState=1906 155243,11 5 LsXferPlayAnn EV_PLAY_FINISHED 155243,12 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 155243,12 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 155243,14 5 sVbsFunctionToUse=Digits 155243,27 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 155243,32 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 155243,33 5 play set playid=69007 155243,34 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 155243,34 5 timer clear 155243,35 5 wa(6941,6900701) 155243,36 5 callinfo MONITORMODES 155250,34 5 wb(6900701) 155250,42 5 play end current play (playid=69007) 155250,42 5 ScriptEventCode 8001 iLineState=1906 155250,43 5 LsXferPlayAnn EV_PLAY_FINISHED 155250,43 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 155250,43 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 155250,53 5 sVbsFunctionToUse=Digits 155250,58 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 155250,64 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 155250,64 5 play set playid=76318 155250,66 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 155250,66 5 timer clear 155250,67 5 wa(6941,7631801) 155250,67 5 callinfo MONITORMODES 155257,67 5 play end current play (playid=76318) 155257,67 5 ScriptEventCode 8001 iLineState=1906 155257,67 5 LsXferPlayAnn EV_PLAY_FINISHED 155257,68 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 155257,68 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 155257,70 5 sVbsFunctionToUse=Digits 155257,85 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 155257,89 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 155257,90 5 play set playid=83578 155257,90 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 155257,91 5 timer clear 155257,91 5 wa(6941,8357801) 155257,92 5 callinfo MONITORMODES 155304,90 5 wb(8357801) 155304,99 5 play end current play (playid=83578) 155304,99 5 ScriptEventCode 8001 iLineState=1906 155304,00 5 LsXferPlayAnn EV_PLAY_FINISHED 155305,01 5 tapic lineGenerateDigits(65929,!,100) => 0 155305,68 5 generate LINEGENERATETERM_DONE 155305,68 5 timer set 1 EV_TAPI_GENERATE 155306,62 5 timer fired EV_TAPI_GENERATE 155306,62 5 ScriptEventCode 9602 iLineState=1906 155306,62 5 LsXferPlayAnn EV_TAPI_GENERATE 155306,62 5 eng PlayFinishCause=CallAcceptWaitTimedOut 155306,63 5 eng Timeout path not defined - hanging up (iXferType=1) 155306,64 5 rv add [Hangup Time]{21/04/2005 15:53:06} 155306,66 5 Hanging up call... [LsXferPlayAnn CallAcceptWaitTimedOut] 155306,77 5 RecSoundStop ok 155306,77 5 PlaySoundStop err=0 155306,77 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 155306,79 5 fnHangupCall end 155306,83 5 linedevstate 2048 0 0 155306,83 5 callstate IDLE 65929 0 0 155306,84 5 WorkingMode@Idle= 155306,84 5 timer clear 155306,86 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 155306,98 5 tapi Reply (LineEvReply) ok 65776 0 155307,86 5 timer fired EV_TIMEOUT_TIMETOREINITLINE 155307,86 5 ScriptEventCode 9008 iLineState=900 155307,86 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 155307,86 5 ReinitTelephony due to IDLE 155307,87 5 tapic lineDeallocateCall(MainCall:65929) 0 155308,02 5 lineOpen(5)=> 155308,03 5 Waiting for a call... 155308,03 5 LineHandle=65827 155308,03 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 155308,39 0 dial start any summary:|5:rdy=0|6:idx=0| 155311,05 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 155311,05 5 ScriptEventCode 9013 iLineState=900 155311,46 0 dial start any summary:|5:idx=0|6:idx=0| Share this post Link to post
SupportTeam Report post Posted 04/21/2005 09:43 PM Sounds like your Dialogic card's hookflash length is set too high. see: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm Share this post Link to post
tommie Report post Posted 04/22/2005 06:44 AM Dear, I tried changing the values and restarted the dialogic service. However this is still not working. Here is my log: 084330,49 5 linedevstate 2048 0 0 084330,52 5 callstate OFFERING 65554 0 4 084330,52 5 callinfo CALLEDID 084330,52 5 callinfo ORIGIN 084330,52 5 ring 0 084331,41 0 dial start any summary:|5:hc>0|6:idx=0| 084336,70 5 ring 2 084336,70 5 rv clear 084336,72 5 Answer the call at 22/04/2005 8:43:36 084336,73 5 lineAnswer(65554) => 65571 084337,28 5 callstate CONNECTED 65554 1 0 084337,28 5 callstate CONNECTED 65554,1,0 084337,28 5 WorkingModeTAPI@Connected= 084337,28 5 WorkingModeScript@Connected= 084337,34 5 Inband detection not enabled 084337,35 5 StartLoadedVgs at 22/04/2005 8:43:37, v5.2.3063 084337,35 5 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\} 084337,36 5 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts} 084337,36 5 rv add [$RV_STARTTIME]{22/04/2005 8:43:37} 084337,36 5 rv add [$RV_DEVICEID]{5} 084337,36 5 rv add [$RV_CIDNAME]{} 084337,36 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 084337,36 5 rv add [$RV_CIDNUMBER]{} 084337,38 5 tapi Reply (LineEvReply) ok 65571 0 084337,39 5 callinfo MONITORMODES 084337,41 5 timer clear 084337,42 5 [Welkom@yora] Playing 084337,42 5 [Welkom@yora] Playing (N:\Telefooncentrale\welkom bij yora.wav) 084337,43 5 play set playid=723113 084337,78 5 PlaySoundStart ok [N:\Telefooncentrale\welkom bij yora.wav] 084337,78 5 timer clear 084337,78 5 RunModule PLAY end 084337,79 5 wa(5507,72311300) 084337,84 5 callinfo MONITORMODES 084343,37 5 play end current play (playid=723113) 084343,37 5 ScriptEventCode 8001 iLineState=1100 084343,39 5 LsPlayMsg EV_PLAY_FINISHED 084343,40 5 eng set timer EV_TIMEOUT_REPLAYMSG time=5 084343,40 5 timer set 5 EV_TIMEOUT_REPLAYMSG 084343,69 5 dtmf 3 (65554,51,2) 084343,70 5 ScriptEventCode 51 iLineState=1101 084343,70 5 LsPlayMsgFinished 3 084343,70 5 rv add [Welkom@yora]{3} 084343,70 5 timer clear 084343,70 5 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER 084344,04 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 084344,04 5 ScriptEventCode 9012 iLineState=1900 084344,04 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 084344,05 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 084344,05 5 [reclame@yora] Announced Transfer to 548 (Generate) 084344,07 5 tapic lineGenerateDigits(65554,!,100) => 0 084344,73 5 generate LINEGENERATETERM_DONE 084344,73 5 timer set 1 EV_TAPI_GENERATE 084345,69 5 timer fired EV_TAPI_GENERATE 084345,69 5 ScriptEventCode 9602 iLineState=1900 084345,69 5 LsXferStart EV_TAPI_GENERATE 084345,70 5 timer set 1 EV_HOOKFLASHFINISHED 084346,70 5 timer fired EV_HOOKFLASHFINISHED 084346,70 5 ScriptEventCode 9200 iLineState=1905 084346,70 5 LsXferPlayVts EV_HOOKFLASHFINISHED 084346,71 5 tapic lineGenerateDigits(65554,548,100) => 0 084347,23 5 generate LINEGENERATETERM_DONE 084347,24 5 timer set 1 EV_TAPI_GENERATE 084348,22 5 timer fired EV_TAPI_GENERATE 084348,22 5 ScriptEventCode 9602 iLineState=1905 084348,22 5 LsXferPlayVts EV_TAPI_GENERATE 084348,23 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 084348,33 5 sVbsFunctionToUse=Digits 084348,41 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 084348,56 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 084348,56 5 play set playid=734239 084348,62 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 084348,63 5 timer clear 084348,63 5 wa(6941,73423901) 084348,63 5 callinfo MONITORMODES 084355,65 5 play end current play (playid=734239) 084355,65 5 ScriptEventCode 8001 iLineState=1906 084355,65 5 LsXferPlayAnn EV_PLAY_FINISHED 084355,65 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 084355,66 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 084355,77 5 sVbsFunctionToUse=Digits 084355,81 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 084355,87 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 084355,87 5 play set playid=741550 084355,88 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 084355,89 5 timer clear 084355,89 5 wa(6941,74155001) 084355,91 5 callinfo MONITORMODES 084402,88 5 wb(74155001) 084402,93 5 play end current play (playid=741550) 084402,94 5 ScriptEventCode 8001 iLineState=1906 084402,94 5 LsXferPlayAnn EV_PLAY_FINISHED 084402,94 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 084402,94 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 084402,97 5 sVbsFunctionToUse=Digits 084403,11 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 084403,16 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 084403,17 5 play set playid=748850 084403,18 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 084403,18 5 timer clear 084403,18 5 wa(6941,74885001) 084403,20 5 callinfo MONITORMODES 084408,62 0 sys cleanup Start 084408,62 0 sys cleanup End 084410,18 5 wb(74885001) 084410,24 5 play end current play (playid=748850) 084410,24 5 ScriptEventCode 8001 iLineState=1906 084410,24 5 LsXferPlayAnn EV_PLAY_FINISHED 084410,25 5 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 084410,25 5 fn PlaySoundStartNumbers [TsfrCallFrom.wav],[TsfrAskAccept.wav],[],Digits 084410,28 5 sVbsFunctionToUse=Digits 084410,41 5 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_5_SayNumber.vbs) 084410,45 5 cl Play_Start C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav 084410,46 5 play set playid=756141 084410,47 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav,C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav] 084410,51 5 timer clear 084410,55 5 wa(6941,75614101) 084410,56 5 callinfo MONITORMODES 084417,50 5 play end current play (playid=756141) 084417,51 5 ScriptEventCode 8001 iLineState=1906 084417,51 5 LsXferPlayAnn EV_PLAY_FINISHED 084417,59 5 tapic lineGenerateDigits(65554,!,100) => 0 084418,25 5 generate LINEGENERATETERM_DONE 084418,25 5 timer set 1 EV_TAPI_GENERATE 084419,19 5 timer fired EV_TAPI_GENERATE 084419,19 5 ScriptEventCode 9602 iLineState=1906 084419,19 5 LsXferPlayAnn EV_TAPI_GENERATE 084419,20 5 eng PlayFinishCause=CallAcceptWaitTimedOut 084419,20 5 eng Timeout path not defined - hanging up (iXferType=1) 084419,20 5 rv add [Hangup Time]{22/04/2005 8:44:19} 084419,22 5 Hanging up call... [LsXferPlayAnn CallAcceptWaitTimedOut] 084419,27 5 RecSoundStop ok 084419,33 5 PlaySoundStop err=0 084419,34 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 084419,40 5 fnHangupCall end 084419,46 5 linedevstate 2048 0 0 084419,46 5 callstate IDLE 65554 0 0 084419,46 5 WorkingMode@Idle= 084419,46 5 timer clear 084419,60 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 084419,60 5 tapi Reply (LineEvReply) ok 66408 0 084420,50 5 timer fired EV_TIMEOUT_TIMETOREINITLINE 084420,50 5 ScriptEventCode 9008 iLineState=900 084420,50 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 084420,51 5 ReinitTelephony due to IDLE 084420,51 5 tapic lineDeallocateCall(MainCall:65554) 0 084420,65 5 lineOpen(5)=> 084420,65 5 Waiting for a call... 084420,65 5 LineHandle=66134 084420,66 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 084421,46 0 dial start any summary:|5:rdy=0|6:idx=0| 084423,66 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 084423,66 5 ScriptEventCode 9013 iLineState=900 084424,54 0 dial start any summary:|5:idx=0|6:idx=0| Share this post Link to post
SupportTeam Report post Posted 04/22/2005 08:49 AM Have you used both approaches as described in Help file? esp the .PRM file approach.... What value have you set the hookflash settings to? What hookflash does your PBX expect? Share this post Link to post
tommie Report post Posted 04/25/2005 09:56 AM Dear, I tried the two approaches. But still it is not working. I changed the file eu_d4p.prm. I also restarted the service. When I press 3 to get transfered the call is immediatly interrupted and in the log there is a timeout. I don't know which hookflash the pbx is expecting. Also the callerid is not working. Is this also caused by this. I checked your forum a dozen times and tried everything for the callerid. But also this is not working. Contacting the dialogic dealer in belgium is not helpfull. The said I should contact Intel. However Intel is also not responding to my questions... 115144,71 5 dtmf 3 (66307,51,2) 115144,71 5 ScriptEventCode 51 iLineState=1101 115144,71 5 LsPlayMsgFinished 3 115144,71 5 rv add [Welkom@yora]{3} 115144,78 5 timer clear 115144,78 5 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER 115145,13 5 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 115145,13 5 ScriptEventCode 9012 iLineState=1900 115145,14 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 115145,14 5 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 115145,14 5 [reclame@yora] Announced Transfer to 548 (Generate) 115145,25 5 tapic lineGenerateDigits(66307,!,100) => 0 115145,91 5 generate LINEGENERATETERM_DONE 115145,92 5 timer set 1 EV_TAPI_GENERATE 115146,87 5 timer fired EV_TAPI_GENERATE 115146,87 5 ScriptEventCode 9602 iLineState=1900 115146,87 5 LsXferStart EV_TAPI_GENERATE 115146,88 5 timer set 1 EV_HOOKFLASHFINISHED 115147,88 5 timer fired EV_HOOKFLASHFINISHED 115147,88 5 ScriptEventCode 9200 iLineState=1905 115147,88 5 LsXferPlayVts EV_HOOKFLASHFINISHED Share this post Link to post
SupportTeam Report post Posted 04/25/2005 08:40 PM What values have you set the hookflash settings to? Share this post Link to post
tommie Report post Posted 04/26/2005 06:47 AM Dear, I set it to 10. Like described on http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm I checked the type of PBX we have and it is an Alcatel OmniPCX. Do you have a clue how I can solve the problem? Share this post Link to post
SupportTeam Report post Posted 04/26/2005 09:09 PM Can you do hookflash transfers on that line using a normal analog handset? Try reducing the value to 5 or even 1 and see if that makes any difference. Share this post Link to post
ktruk Report post Posted 04/30/2005 01:59 PM When I had the same problem, it was a combination of hook-flash length and then when that was fixed, I had a problem with disconnect-tone detection, as my PBX gives dial-tone same as disconnect-tone, as the line sees this just after the hook-flash before dialling the ext number. Solution was to increase disconnect tone detection timing by pushing it out to 2.5/3 secs (as VG has a 1 or 2 second 'built-in" wait-after-flash delay - its a combination of something in the VG.INI and a 1 sec built in constant). That fixed it. (Set the delay in the on/off time in the TSP disconnect tone settings). Good luck - Tim. Share this post Link to post
ktruk Report post Posted 04/30/2005 02:12 PM Oh, and by the way, I had to set the hook-flash in the dialogic parameter file as the settings in the TSP dialog screen are just ignored!! Share this post Link to post
tommie Report post Posted 06/03/2005 11:08 AM I'm sorry for not answering anymore. But I have been ill. However now I am working further to solve this problem. I set the hookflashlength to 1. Immediately after pressing 3 on the phone I get this: 131104,41 8 dtmf 3 (66425,51,2) 131104,41 8 ScriptEventCode 51 iLineState=1100 131104,41 8 LsPlayMsg 3 131104,46 8 PlaySoundStop err=0 131104,46 8 rv add [Welkom@yora]{3} 131104,46 8 timer clear 131104,46 8 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER 131104,87 8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 131104,87 8 ScriptEventCode 9012 iLineState=1900 131104,87 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 131104,87 8 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 131104,88 8 [reclame@yora] Announced Transfer to 548,,, (Generate) 131104,89 8 tapic lineGenerateDigits(66425,!,100) => 0 131105,55 8 generate LINEGENERATETERM_DONE 131105,55 8 timer set 1 EV_TAPI_GENERATE 131106,49 8 timer fired EV_TAPI_GENERATE 131106,50 8 ScriptEventCode 9602 iLineState=1900 131106,50 8 LsXferStart EV_TAPI_GENERATE 131106,50 8 timer set 1 EV_HOOKFLASHFINISHED 131107,54 8 timer fired EV_HOOKFLASHFINISHED 131107,54 8 ScriptEventCode 9200 iLineState=1905 131107,54 8 LsXferPlayVts EV_HOOKFLASHFINISHED 131107,55 8 tapic lineGenerateDigits(66425,548,,,,100) => 0 131114,16 8 generate LINEGENERATETERM_DONE 131114,16 8 timer set 1 EV_TAPI_GENERATE 131115,13 8 timer fired EV_TAPI_GENERATE Other Ideas? Share this post Link to post
tommie Report post Posted 06/03/2005 06:22 PM Hi, I have now upgraded to voiceguide 6.0.2 for dialogic. And everything is working now!!! Marvelous! Regards, Tommie Share this post Link to post
