Script_gosub
Hi
I am trying to build my own function that creates a string or file names from a number. This string is then available for the following modules. I will be calling the module from several different places in my script, so I need the function to be flexible
eg:
Number passed in is 123
String created is "one.wav, two.wav,three.wav"
I am trying to make this function available for any module to use. My aproach is
Build a module, say vbsNumbers that creates the string then use
Script_Gosub $RV_LINEID, "", "vbsNumbers", "[numbers]{123}", "", "NextModule"
where next module could be anything.
The code above seems to call the vbsNumbers, but then the script terminates instead of proceeding to NextModule
A have copied the module and use a seperate vbscript module every time I need to say the number, it is not pretty but it works.
I am now having problems with the fisrt digit being zero. If I enter a number 02635444444 then both $RV_ENTEREDNUMBER and the $RV[get number molue ] will omit the leading 0. Ie, these values will be 2635444444
I have tried to cast them as string, or asign them to values that precviously were strings but no luck.
Any help would greatly be appreciated.
