Guest Suhail Report post Posted 04/22/2005 03:14 AM O/S = Windows XP, Service Pack 1 Voice Modem = Intel® 537EP V9x DFV PCI Modem Probelm Description: The caller hears two rings fine and then there just the silence. Using VG "Hangup call" (hit the button) and call again. Once again caller hears two rings and then there's silence. VG State shows "Waiting for a call" VG Event Trace Log shows the following: ======================================== 200343.59 0 ring 1 200349.59 0 ring 2 200411.86 0 btn Hangup on line 0 200411.88 0 rv add [Hangup Time]{4/21/2005 8:04:11 PM} 200411.88 0 Hanging up call... 200411.88 0 RecSoundStop ok 200411.89 0 PlaySoundStop err=0 200411.89 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 200411.89 0 HangupCall : lCallHandle& = 0 - lets close and open line 200411.91 0 ReinitTelephony due to IDLE 200411.97 0 lineOpen(0)=> 200411.97 0 Waiting for a call... 200411.97 0 LineHandle=66407 200411.97 0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 200411.97 0 Waiting for a call... 200411.98 0 fnHangupCall end 200415.16 0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 200415.16 0 ScriptEventCode 9013 iLineState=900 200425.25 0 ring 1 200431.30 0 ring 2 ============================================= The same machine with the same modem has worked in the past. Please help. Thank you, Suhail. Share this post Link to post
SupportTeam Report post Posted 04/22/2005 06:41 AM Don't know why the modem is not working... The modem drivers only report first two rings and that's it... Share this post Link to post
