Output Call ?
hi
we have a VG professional + dialer 8 line
in our script when we try to use dialout on other line and conference the line hungup
and when we trace it using log trace the following error was found
no free line was Available , but in fact all the line was Available except the one that calling the VG
so what is the problem??
Do any of the lines have the "Allow outbound dialout on this line" ticked?
See the "View"->"Line Device Config" menu.
If the problem persists please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going on.
You can enable the automatic saving of the logs to files in \log\ directory as well.
Which version of VG are you using?
v5.2.3 or some earlier one?
Can you please supply trace showing the initialization of the system at startup time.
how can i do that ?
Tick the "Create log files in \log\ directory" then restart VG.
Log files will be in VG's \log subdirectory.
dear:
i think this my help you ,we have 8 line licence,but we only have card that support 4 line so is this what make the problem or it does not effect,hope to hear from you soon
Trace shows that the transfer module has a 'selection list' specified - and that the selection list does not include any of the 3 available channels.
I'd suggest not setting anything for your selection list - just leave it blank.
Also please install the latest version of VG from our WWW - v5.2.3b
If you are still having problems please post your script and vgm trace when using v5.2.3b.
