Guest omar_f Report post Posted 04/24/2005 03:18 PM hi we have a VG professional + dialer 8 line in our script when we try to use dialout on other line and conference the line hungup and when we trace it using log trace the following error was found no free line was Available , but in fact all the line was Available except the one that calling the VG so what is the problem?? Share this post Link to post
SupportTeam Report post Posted 04/24/2005 07:45 PM Do any of the lines have the "Allow outbound dialout on this line" ticked? See the "View"->"Line Device Config" menu. If the problem persists please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going on. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well. Share this post Link to post
Guest omar_f Report post Posted 04/25/2005 05:49 AM hi all of the line allow VG to dialout on it, i will send to you a trace log OutDial.txt Share this post Link to post
SupportTeam Report post Posted 04/25/2005 07:01 AM Which version of VG are you using? v5.2.3 or some earlier one? Can you please supply trace showing the initialization of the system at startup time. Share this post Link to post
Guest omar_f Report post Posted 04/25/2005 07:50 AM i use version v5.2.3 Share this post Link to post
SupportTeam Report post Posted 04/25/2005 08:38 PM Can you please supply trace showing the initialization of the system at startup time Share this post Link to post
Guest omar_f Report post Posted 04/26/2005 11:13 AM how can i do that ? Can you please supply trace showing the initialization of the system at startup time Share this post Link to post
SupportTeam Report post Posted 04/26/2005 09:11 PM Tick the "Create log files in \log\ directory" then restart VG. Log files will be in VG's \log subdirectory. Share this post Link to post
Guest omar_f Report post Posted 04/27/2005 05:34 AM ok i did what you ask 0427sw.txt Share this post Link to post
Guest omar_f Report post Posted 04/27/2005 05:46 AM this is the second log 0427tw.txt Share this post Link to post
Guest omar_f Report post Posted 04/27/2005 07:12 AM dear: i think this my help you ,we have 8 line licence,but we only have card that support 4 line so is this what make the problem or it does not effect,hope to hear from you soon Share this post Link to post
SupportTeam Report post Posted 04/27/2005 07:47 AM Trace shows that the transfer module has a 'selection list' specified - and that the selection list does not include any of the 3 available channels. I'd suggest not setting anything for your selection list - just leave it blank. Also please install the latest version of VG from our WWW - v5.2.3b If you are still having problems please post your script and vgm trace when using v5.2.3b. Share this post Link to post
