Guest aryads Report post Posted 04/26/2005 05:43 AM hello does VoiceGuide support D/160 SC LS REV.2 D/320 SC Rev.2 my problem is how i can use it? because it does not have any PSTN RG11 port do you have any manual how i can use it best regards Share this post Link to post
SupportTeam Report post Posted 04/26/2005 06:18 AM The "LS" card will have the line interface on it (LS stands for "Loop Start") so you can connect the phone lines direct to it. The D/320SC does not accept phone lines, it is a "Resource Only" card. You can still use it in conjunction with cards like DTI301 and other similar "Interface Only" cards - but these are mostly old ISA type cards... Share this post Link to post
Guest aryads Report post Posted 04/26/2005 01:24 PM what about this one? DIALOGIC D/160 SC LS REV.2 HIZ can i use this card with VoiceGuide? Share this post Link to post
SupportTeam Report post Posted 04/26/2005 09:13 PM No. The HIZ cards are high impdance cards designed for call recording only. There cards are not able to answer incoming calls. Recommended hardware is listed here: http://www.voiceguide.com/suppRecomHardware.htm Share this post Link to post
