3 Way Call Support Vs Call Transfer
I am doing a transfer with the 3 way blind cc option, and I have 3 way calling as opposed to call transfer service from my telco- the result of this is that the line connected to the voice guide server has to stay connected to keep the call alive. The behavior that I am seeing is that voice guide transfer upon success is hanging up and terminating the call. This would be great if I had call transfer instead of 3 way calling. I have tried removing the success -> hangup path, but then voice guide never seems to hang up the call after both of the other lines have hung up- in some cases it then calls back the original caller to reconnect the call- How can I get vg to stay on the line until one of the other lines have hung up and then hang up? I have a licensed copy of 4.7x enterprise, but I am testing on the current build with plans to upgrade upon success-
Thanks-
If you have that path defined that it will be taken immediately after conferencing the 3rd party in - and if you point it to a Hangup module then yes the 3 way conf will then finish.
Use this path only to start a recording module to record the call, or some other module which awaits callers input.
Are you using a voice modem or a Dialogic card?
Is 'end of call tone' detection working on other calls?
Does the phone company send the 'end of call tone' when either party hangs up?
i appreciate the quick response- :)
I am using a way2call desktop- in testing, I obviously exhausted the licensing trial - is there a way I can reset this to continue testing?
You said -
If I do not have success-> hangup, how do I get it to hang up after I hang up?
you said-
I am not sure- their office is closed at this hour- How can I verify the eoc tone detection without the telco info?
thanks-
ok, i figured out how to reset the trial-
I have removed the success-> hangup path, unfortunately, whatever the end of call signal is, it is not being interpreted correctly
also, can I remove the dtmf 3 tone?- my telco only requires a ! to complete the 3 way call-
thanks-
Does the phone company play any tones/beeps when either party hangs up?
In Script Designer go to Edit menu and select "PBX Command Strings"
no, there is no tone to indicate an eoc- i removed the 3- thx is there any other way to sense the eoc?
On analog lines from the phone company you can only tell that a call has finished if the phone company plays a 'disconnect' tone (ie: beep-silence-beep-... etc etc) or if the lines Loop Current is cut by the phone company.
Ask your phone company if maybe they can set up these lines to either play a tone or drop the loop current. If they cannot do that then the only option is to get another card and another line and do "Dial and Conference" type connections - assuming that disconnect tone is played when normal calls end...
