Guest David Friedman Report post Posted 05/04/2005 04:21 PM Hi, Will the D/4PCIU update for System Release 5.1.1 work with the D/4PCIUF card? David Share this post Link to post
Guest John Morrissey Report post Posted 08/29/2005 08:12 PM I have installed SR 5.1.1 with Service Pack and D/4PCIU "patch" However, my D/4PCIUF card is recognized by Windows as a D/4JCT card for some reason and cann ot load the proper driver. Anyone ever seen this or do you really need SR 6.0 for proper support of the D/4PCIUF? Share this post Link to post
SupportTeam Report post Posted 08/29/2005 08:14 PM Does the Dialogic Configuration Manager recognise the card correctly? Share this post Link to post
Guest John Morrissey Report post Posted 08/30/2005 01:24 PM The dialogic configuration manager does recognize the card correctly and the proper model but Windows does not and sees it as the D/41JCT card. According to Intel's site you need th Feature Pack for the D/4PCIUF. However, have you found that as long as the Intel configuration manager recognizes the card properly it will work fine with VoiceGuide? Share this post Link to post
SupportTeam Report post Posted 08/30/2005 02:22 PM The dialogic configuration manager does recognize the card correctly and the proper model Great. That's all that you need. Windows does not and sees it as the D/41JCT card. You can ignore how Windows detects the card. as long as the Intel configuration manager recognizes the card properly it will work fine with VoiceGuide? Correct. Share this post Link to post
