ktruk Report post Posted 05/04/2005 08:00 PM Hi, I would like to relocate the VM system from "C:\Program Files\VoiceGuide\data\VmSave\" to somewhere else (also the mailbox names/greetings too). If this means moving the VM scripts too then that is okay. Any advice please? thx - tim. Share this post Link to post
SupportTeam Report post Posted 05/04/2005 10:26 PM Sure. Just edit the voicemail scripts in VG's \system\vm\ subdirectory to use a different directory. Pretty much just do a search and replace in all the .VGS files using a text editor. You will need an Enterprise version of VG to be able to use the modified scripts. (Pro version uses the unmodifiable .VGP scripts) Share this post Link to post
