Guest Simon Brazier Report post Posted 05/23/2003 10:57 AM Help !! We're currently running a trial using VoiceGuide version 4.9.0 on a Windows NT4 workstation with service pack 6 installed and have installed MDAC 2.6 as suggested in your helpfiles. The hardware is better than your minimum suggested spec, and the sound hardware we are using is a Dialogic DESC card. We initially tried to query a SQL database from a script that we had designed ourselves, using ODBC, but had no luck. Eventually we gave up and tried to query an Access database from our own script, and that failed too - so in the end we loaded up "Get Price.vgs" from your sample scripts, just to see if that would query your sample database. We get a failure everytime - the log file all looks fine apart from the following line: 78297 0 ERROR 4.9.0 OpenDatabse [91:Object variable or With block variable not set] This occurs even on an unmodified version of your Get Price script. Can you help and point us in the right direction as to what we've got wrong ? Thanks Share this post Link to post
