Guest Buzby Report post Posted 05/05/2005 01:05 PM A quick question regarding the VB Script 'VBS' files that are created in the VoiceGuide\Data directory: The VB Scripts I've written in my application change in accordance with the activities of the user during their time on the phone. It appears that everytime a call is made into my script, a new set of VBS files are deposited into the VoiceGuide\Data directory. This makes sense, because I understand how VoiceGuide passes the VBS files to an external parser for execution, then retrieves the results for use back in the script. However, when I deploy my script into live usage, I am a bit concerned about the Data directory becoming clogged up with redundant VBS files, particularly as I am expecting 1000's of calls on a daily basis. I haven't seen these files automatically removed as yet, although I do appreciate that my test server hasn't really been running for that much time yet. Does VoiceGuide have a policy for removal of these files after use? Are there any efficiency practices I can use? Many thanks! Share this post Link to post
SupportTeam Report post Posted 05/05/2005 10:53 PM Quote It appears that everytime a call is made into my script, a new set of VBS files are deposited into the VoiceGuide\Data directory. Not quite the case. The .VBS files are named like this: vbs_iLineId_iIndex.vbs where the iIndex starts at 1 on each new call. So new .vbs files will overwrite the older .vbs files from the previous call on the same line. So at any one time you always have a record of what VBScripts were ran by a particular line during the last call. Share this post Link to post
