ckreis Report post Posted 05/11/2005 05:50 PM If we (under Win2K): Put some components into VG script designer. Connect them with paths. Delete the destination components. Right click on the properties button of the first step component. The pop up menu which appears is only a few millimeters wide and no longer shows the items (i.e. Properties, On 1 goto, etc...) Share this post Link to post
SupportTeam Report post Posted 05/11/2005 10:12 PM We could not reproduce the error using the steps you provided. Which version of VG are you using? Share this post Link to post
Guest Guest_Chris Report post Posted 05/12/2005 12:35 AM Add a play component, then add a database component, draw a path between the two. Add another db component, draw a path, remove them both, right click on play component. Try this a few times til it happens. When it happens, all the menus (i.e. main menus) get a little funky too; i.e. they are all highlighted with a light gray. We have version 5.3.3028. It happens on Win2k and XP. Great software otherwise btw! Good luck... Share this post Link to post
SupportTeam Report post Posted 05/12/2005 12:39 AM ... still no luck reproducing it here. Will make a note of this and keep an eye out for it. Share this post Link to post
