No Cid Value
Hi Support Team,
I am using Voiceguide Enterprise on a ISDN E1 system.
We have 26 incoming digital lines active and 4 analouge lines to transfer calls into our PABX.
I must capture the CID number where available.
Unless I am referencing the CIDNUMBER in an incorrect way, It is not being populated at any stage durin the call.
Below is the TW log and I have attached the Call trace.
101221.680 028 ev metaevent: cclibid=0x2, crn=0x200807a, evtdatap=0xd852fb0, evtdev=0x1c, evtlen=0x1c, evttype=0x824, extevtdatap=0x0, flags=0x1, linedev=0x1c, magicno=0xbad012fb, rfu1=0x2, usrattr=0x5c10048 (usrattr=hli)
101221.680 028 ev GCEV_OFFERED
101221.680 ocxev DoFireDialogic(dwIdx=37, 28, 2084, [GCEV_OFFERED], 2084, 0, 0, [], [], [])
101221.680 gc ERROR CCLIB specific, line=778 module=C:\Projects\TapiWrap for Dialogic\EvHandlers.cpp
101221.680 gc ERROR Invalid parameter, line=785 module=C:\Projects\TapiWrap for Dialogic\EvHandlers.cpp
101221.680 028 ocxev CallerId(sLineId=28, hCall=0(0x0), crn=33587322(0x200807a) strCallerID=[], strName=[], strDialed=[89761905])
101221.696 ocxfn LogLevels 10,C:\Program Files\VoiceGuide\log\,tw.txt,0,
101221.696 028 te LINE_CALLSTATE(28, 0x1c, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING
101221.696 ev028 OnFireCallerIdArrived (hli=0x5c10048)
101222.227 028 ocxfn LineAnswer(lLineId=28, lParam=0, strParam=)
101222.227 028 ev metaevent: cclibid=0x2, crn=0x200807a, evtdatap=0xd844e78, evtdev=0x1c, evtlen=0x1c, evttype=0x804, extevtdatap=0x0, flags=0x1, linedev=0x1c, magicno=0xbad012fb, rfu1=0x2, usrattr=0x5c10048 (usrattr=hli)
101222.227 028 ev GCEV_ACCEPT
101222.337 028 ev metaevent: cclibid=0x2, crn=0x200807a, evtdatap=0xd844e78, evtdev=0x1c, evtlen=0x1c, evttype=0x802, extevtdatap=0x0, flags=0x1, linedev=0x1c, magicno=0xbad012fb, rfu1=0x2, usrattr=0x5c10048 (usrattr=hli)
101222.337 028 ev GCEV_ANSWERED
101222.352 gc gc_AttachResource(28,27) error (digital line)
101222.352 gc gc_AttachResource(28,27) error (digital line) failed, gc(0x44) - Invalid parameter, cc(0x38a) - Bad input parameter
101222.352 ocxev DoFireDialogic(dwIdx=39, 28, 2050, [GCEV_ANSWERED], 2050, 0, 0, [], [], [])
101222.352 028 te LINE_CALLSTATE(28, 0x1c, 0x100, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_CONNECTED
101222.352 028 ocxfn ConvertWav2Vox(hLine=28, lTaskID=133390, strWavFilesIn=C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.wav, strConvertOptions=, lParam1=1, lParam2=0, strParam1=, strParam2=)
101222.383 conv start on idx 52 [C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.wav]
101222.383 conv start on token 0 [C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.wav]
101222.383 conv finished converting
101222.383 evt OnFireConvertWavVoxFinished wParam=52 lParam=0
101222.383 028 ocxev ConvertWavVoxFinished(28, 133390, C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.vox, 1, 0, , )
101222.383 028 ocxfn PlayStart(hLine=28, strSoundFile=C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.vox, lPlayId=133421(0x2092d), lParam1=0, lParam2=0, strParam1=, strParam2=, 0,,,,,,,,,,)
101222.383 ocxfn PlaySetControlKeys(28,0,,,,,,,,,,)
101222.383 play start (hli=0x5c10048, strSoundFile=C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.vox, lPlayId=133421(0x2092d), lParam1=0, lParam2=0, strParam1=, strParam2=)
101222.383 play open(strFname[0]=C:\Promotion Files\P0006\PromptWavs\3 Greeting Instructions.vox) => 3, read_bytes=38474/38474, buff_addr=0xd861ec8 (file_created_time=Tue Apr 12 09:55:25 2005
, file_modified_time=Tue Apr 12 09:55:25 2005
101222.383 iott 0xd844e78 io_type=14, io_fhandle=0, io_bufp=0xd861ec8, io_offset=0, io_length=38474, io_nextp=0x0, io_prevp=0x0
101222.383 dlgc dx_playiottdata(27, 0xd844e78, 0x5c10ce8, 0x5c10e28, EV_ASYNC) call
101222.383 dlgc play(27, 0xd844e78, 0x5c10ce8, 0x5c10e28) => 0, hli=0x5c10048
101232.071 027 ev TDX_PLAY (Play Completed)
101232.071 play free(0xd861ec8, 0xd844e78) eot
101232.071 cleared dwPlayId: hli=0x5c10048, hli->dwPlayId=0(0x0)
101232.071 028 ocxev PlayEnd(dwLineId=28, dwPlayId=133421)
101232.071 ocxev DoFireDialogic(dwIdx=41, 28, 129, [TDX_PLAY], 133421, 0, 0, [], [], [])
101232.087 028 ocxfn SilenceDetectSet(sLineId=28, sTimeLen100msUnits=30, sVolumeLevel=10)
101232.087 028 ocxfn RecStart(hLine=28, strSoundFile=C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.wav, lRecId=143125, lParam1=1, lParam2=0, strParam1=, strParam2=)
101232.087 rec start
101232.087 dlgc dx_fileopen call
101232.087 dlgc dx_fileopen(strFname=C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox) => 3
101232.087 dlgc TPT DX_MAXSIL's tp_length = 30
101232.087 dlgc record(20, ...) => 0, hli=96534600
101238.071 027 ev TDX_CST (CST Event Received)
101238.071 027 ev TDX_CST DE_DIGITS data=35 [#]
101238.071 028 te LINE_MONITORDIGITS(28, 0x1c, 0x23, 0x23)
101238.071 028 ocxfn RecStopTruncate(sLineId=28, strSaveFname=, lTruncTime=500 (milliseconds), lTruncBytes=0)
101238.087 027 ev TDX_RECORD (Record Completed)
101238.087 027 termmask=TM_USRSTOP
101238.087 027 ev TDX_RECORD, TERMMSK=TM_USRSTOP
101238.087 rec dx_fileclose 3 ok
101238.087 rec cut change length (time derived) by:-2000
101238.087 rec cut CreateFile(C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox, OPEN_EXISTING) => 8476
101238.087 rec cut (in event) change length 21936 by -2000, final_len=19936
101238.087 ocxev DoFireDialogic(dwIdx=43, 28, 134, [TDX_CST], 35, 0, 0, [DE_DIGITS], [], [])
101238.087 ocxev DoFireDialogic(dwIdx=44, 28, 130, [TDX_RECORD], 0, 0, 0, [TM_USRSTOP], [], [])
101238.134 conv start on idx 53 [C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox]
101238.134 conv start on token 0 [C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox]
101238.134 conv test opening output file
101238.134 conv vox2wav call strVoxIn=[C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox], strWavOut=[C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.wav]
101238.134 conv C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.vox -> C:\Promotion Files\P0006\EntryWavs\28A000002378IVR2.wav
101238.134 conv finished converting
101238.134 027 ocxev RecEnd(dwLineId=27, dwIdxConvertStoreData=53)
101238.134 028 ocxfn ConvertWav2Vox(hLine=28, lTaskID=149171, strWavFilesIn=C:\Promotion Files\P0006\PromptWavs\6 Key In Code.wav, strConvertOptions=, lParam1=1, lParam2=0, strParam1=, strParam2=)
101238.180 conv start on idx 54 [C:\Promotion Files\P0006\PromptWavs\6 Key In Code.wav]
101238.180 conv start on token 0 [C:\Promotion Files\P0006\PromptWavs\6 Key In Code.wav]
101238.180 conv finished converting
101238.180 evt OnFireConvertWavVoxFinished wParam=54 lParam=0
101238.180 028 ocxev ConvertWavVoxFinished(28, 149171, C:\Promotion Files\P0006\PromptWavs\6 Key In Code.vox, 1, 0, , )
101238.180 028 ocxfn PlayStart(hLine=28, strSoundFile=C:\Promotion Files\P0006\PromptWavs\6 Key In Code.vox, lPlayId=149218(0x246e2), lParam1=0, lParam2=0, strParam1=, strParam2=, 0,,,,,,,,,,)
101238.180 ocxfn PlaySetControlKeys(28,0,,,,,,,,,,)
101238.180 play start (hli=0x5c10048, strSoundFile=C:\Promotion Files\P0006\PromptWavs\6 Key In Code.vox, lPlayId=149218(0x246e2), lParam1=0, lParam2=0, strParam1=, strParam2=)
101238.180 play open(strFname[0]=C:\Promotion Files\P0006\PromptWavs\6 Key In Code.vox) => 3, read_bytes=45405/45405, buff_addr=0xd861ec8 (file_created_time=Tue Apr 12 09:55:41 2005
, file_modified_time=Tue Apr 12 09:55:41 2005
101238.180 iott 0xd844e78 io_type=14, io_fhandle=0, io_bufp=0xd861ec8, io_offset=0, io_length=45405, io_nextp=0x0, io_prevp=0x0
101238.180 dlgc dx_playiottdata(27, 0xd844e78, 0x5c10ce8, 0x5c10e28, EV_ASYNC) call
101238.180 dlgc play(27, 0xd844e78, 0x5c10ce8, 0x5c10e28) => 0, hli=0x5c10048
101246.993 027 ev TDX_CST (CST Event Received)
101246.993 027 ev TDX_CST DE_DIGITS data=49 [1]
101246.993 028 te LINE_MONITORDIGITS(28, 0x1c, 0x31, 0x31)
101246.993 028 ocxfn PlayStop(hLine=28, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
101247.009 027 ev TDX_PLAY (Play Completed)
101247.009 play free(0xd861ec8, 0xd844e78) eot
101247.009 cleared dwPlayId: hli=0x5c10048, hli->dwPlayId=0(0x0)
101247.009 ocxev DoFireDialogic(dwIdx=46, 28, 134, [TDX_CST], 49, 0, 0, [DE_DIGITS], [], [])
101247.009 028 ocxev PlayEnd(dwLineId=28, dwPlayId=149218)
101247.009 ocxev DoFireDialogic(dwIdx=47, 28, 129, [TDX_PLAY], 149218, 0, 0, [], [], [])
101247.321 027 ev TDX_CST (CST Event Received)
101247.321 027 ev TDX_CST DE_DIGITS data=50 [2]
101247.321 028 te LINE_MONITORDIGITS(28, 0x1c, 0x32, 0x32)
101247.337 ocxev DoFireDialogic(dwIdx=49, 28, 134, [TDX_CST], 50, 0, 0, [DE_DIGITS], [], [])
101247.681 027 ev TDX_CST (CST Event Received)
101247.681 027 ev TDX_CST DE_DIGITS data=51 [3]
101247.681 028 te LINE_MONITORDIGITS(28, 0x1c, 0x33, 0x33)
101247.681 ocxev DoFireDialogic(dwIdx=51, 28, 134, [TDX_CST], 51, 0, 0, [DE_DIGITS], [], [])
101248.056 027 ev TDX_CST (CST Event Received)
101248.056 027 ev TDX_CST DE_DIGITS data=49 [1]
101248.056 028 te LINE_MONITORDIGITS(28, 0x1c, 0x31, 0x31)
101248.056 ocxev DoFireDialogic(dwIdx=53, 28, 134, [TDX_CST], 49, 0, 0, [DE_DIGITS], [], [])
101248.415 027 ev TDX_CST (CST Event Received)
101248.415 027 ev TDX_CST DE_DIGITS data=50 [2]
101248.415 028 te LINE_MONITORDIGITS(28, 0x1c, 0x32, 0x32)
101248.415 ocxev DoFireDialogic(dwIdx=55, 28, 134, [TDX_CST], 50, 0, 0, [DE_DIGITS], [], [])
101248.774 027 ev TDX_CST (CST Event Received)
101248.774 027 ev TDX_CST DE_DIGITS data=51 [3]
101248.774 028 te LINE_MONITORDIGITS(28, 0x1c, 0x33, 0x33)
101248.774 ocxev DoFireDialogic(dwIdx=57, 28, 134, [TDX_CST], 51, 0, 0, [DE_DIGITS], [], [])
101249.181 027 ev TDX_CST (CST Event Received)
101249.181 027 ev TDX_CST DE_DIGITS data=49 [1]
101249.181 028 te LINE_MONITORDIGITS(28, 0x1c, 0x31, 0x31)
101249.196 ocxev DoFireDialogic(dwIdx=59, 28, 134, [TDX_CST], 49, 0, 0, [DE_DIGITS], [], [])
101249.681 027 ev TDX_CST (CST Event Received)
101249.681 027 ev TDX_CST DE_DIGITS data=35 [#]
101249.681 028 te LINE_MONITORDIGITS(28, 0x1c, 0x23, 0x23)
101249.681 ocxev DoFireDialogic(dwIdx=61, 28, 134, [TDX_CST], 35, 0, 0, [DE_DIGITS], [], [])
101249.712 028 ocxfn ConvertWav2Vox(hLine=28, lTaskID=160750, strWavFilesIn=C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.wav, strConvertOptions=, lParam1=1, lParam2=0, strParam1=, strParam2=)
101249.759 conv start on idx 55 [C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.wav]
101249.759 conv start on token 0 [C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.wav]
101249.759 conv finished converting
101249.759 evt OnFireConvertWavVoxFinished wParam=55 lParam=0
101249.759 028 ocxev ConvertWavVoxFinished(28, 160750, C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.vox, 1, 0, , )
101249.759 028 ocxfn PlayStart(hLine=28, strSoundFile=C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.vox, lPlayId=160796(0x2741c), lParam1=0, lParam2=0, strParam1=, strParam2=, 0,,,,,,,,,,)
101249.759 ocxfn PlaySetControlKeys(28,0,,,,,,,,,,)
101249.759 play start (hli=0x5c10048, strSoundFile=C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.vox, lPlayId=160796(0x2741c), lParam1=0, lParam2=0, strParam1=, strParam2=)
101249.759 play open(strFname[0]=C:\Promotion Files\P0006\PromptWavs\9 Just a Moment.vox) => 3, read_bytes=2839/2839, buff_addr=0x4306410 (file_created_time=Tue Apr 12 09:55:53 2005
, file_modified_time=Tue Apr 12 09:55:53 2005
101249.759 iott 0xd844e78 io_type=14, io_fhandle=0, io_bufp=0x4306410, io_offset=0, io_length=2839, io_nextp=0x0, io_prevp=0x0
101249.759 dlgc dx_playiottdata(27, 0xd844e78, 0x5c10ce8, 0x5c10e28, EV_ASYNC) call
101249.759 dlgc play(27, 0xd844e78, 0x5c10ce8, 0x5c10e28) => 0, hli=0x5c10048
101250.540 027 ev TDX_PLAY (Play Completed)
101250.540 play free(0x4306410, 0xd844e78) eot
101250.540 cleared dwPlayId: hli=0x5c10048, hli->dwPlayId=0(0x0)
101250.540 028 ocxev PlayEnd(dwLineId=28, dwPlayId=160796)
101250.540 ocxev DoFireDialogic(dwIdx=62, 28, 129, [TDX_PLAY], 160796, 0, 0, [], [], [])
101250.681 028 ocxfn ConvertWav2Vox(hLine=28, lTaskID=161718, strWavFilesIn=C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.wav, strConvertOptions=, lParam1=1, lParam2=0, strParam1=, strParam2=)
101250.728 conv start on idx 56 [C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.wav]
101250.728 conv start on token 0 [C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.wav]
101250.728 conv finished converting
101250.728 evt OnFireConvertWavVoxFinished wParam=56 lParam=0
101250.728 028 ocxev ConvertWavVoxFinished(28, 161718, C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.vox, 1, 0, , )
101250.728 028 ocxfn PlayStart(hLine=28, strSoundFile=C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.vox, lPlayId=161765(0x277e5), lParam1=0, lParam2=0, strParam1=, strParam2=, 0,,,,,,,,,,)
101250.728 ocxfn PlaySetControlKeys(28,0,,,,,,,,,,)
101250.728 play start (hli=0x5c10048, strSoundFile=C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.vox, lPlayId=161765(0x277e5), lParam1=0, lParam2=0, strParam1=, strParam2=)
101250.728 play open(strFname[0]=C:\Promotion Files\P0006\PromptWavs\5 Sorry Not Winner.vox) => 3, read_bytes=25894/25894, buff_addr=0xd861f20 (file_created_time=Tue Apr 12 09:55:54 2005
, file_modified_time=Tue Apr 12 09:55:54 2005
101250.728 iott 0xd844e78 io_type=14, io_fhandle=0, io_bufp=0xd861f20, io_offset=0, io_length=25894, io_nextp=0x0, io_prevp=0x0
101250.728 dlgc dx_playiottdata(27, 0xd844e78, 0x5c10ce8, 0x5c10e28, EV_ASYNC) call
101250.728 dlgc play(27, 0xd844e78, 0x5c10ce8, 0x5c10e28) => 0, hli=0x5c10048
101257.259 027 ev TDX_PLAY (Play Completed)
101257.259 play free(0xd861f20, 0xd844e78) eot
101257.259 cleared dwPlayId: hli=0x5c10048, hli->dwPlayId=0(0x0)
101257.259 028 ocxev PlayEnd(dwLineId=28, dwPlayId=161765)
101257.259 028 ocxfn RecStop(hLine=28, lRecId=143125, lParam1=0, lParam2=0, strParam1=, strParam2=)
101257.259 028 ocxfn PlayStop(hLine=28, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
101257.274 028 ocxfn LineDrop(sLineId=28, sOpt=0)
101257.274 dx_stopch(27) call
101257.274 028 callstate=[GCST_CONNECTED]
101257.274 028 gc dropcall
101257.274 ocxev DoFireDialogic(dwIdx=63, 28, 129, [TDX_PLAY], 161765, 0, 0, [], [], [])
101257.368 028 ev metaevent: cclibid=0x2, crn=0x200807a, evtdatap=0xd844e78, evtdev=0x1c, evtlen=0x1c, evttype=0x805, extevtdatap=0x0, flags=0x1, linedev=0x1c, magicno=0xbad012fb, rfu1=0x2, usrattr=0x5c10048 (usrattr=hli)
101257.368 028 ev GCEV_DROPCALL
101257.368 028 ev metaevent: cclibid=0x2, crn=0x200807a, evtdatap=0xd844e78, evtdev=0x1c, evtlen=0x1c, evttype=0x859, extevtdatap=0x0, flags=0x1, linedev=0x1c, magicno=0xbad012fb, rfu1=0x2, usrattr=0x5c10048 (usrattr=hli)
101257.368 028 ev GCEV_RELEASECALL
101257.368 ocxev DoFireDialogic(dwIdx=64, 28, 2137, [GCEV_RELEASECALL], 2137, 0, 0, [], [], [])
101257.368 028 te LINE_CALLSTATE(28, 0x1c, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE
101257.368 028 ocxfn RecStop(hLine=28, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
101257.368 028 ocxfn PlayStop(hLine=28, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
101258.493 ocxfn RingsBeforeAnswer(lLineId=28, lRings=0, lParam1=0, strParam2=)
Trace shows that CallerID is not provided by the phone company.
They do provide the Indial number, but the CallerID Number and Name fields are left blank.
Maybe the call is made from a phone which has it's CallerID blocked?
If you are making calls from a phone which definitely does not have the CallerID blocked then you should contact your phone company and ask them why aren't they passing on the CallerID.
The line the call was initiated from does not withhold its number.
It must be that caller Id is not activiated.
Cannot believe that is not one of the first things I checked.
Telstra is checkig now.....
