rleflore Report post Posted 05/12/2005 09:47 PM I've setup VG using the trial version and installed the SAPI 5 for TTS. However, when I call into the script, the text in the "Text to Speak" box doesn't playback to the caller. I'm using a D/4PCIUF card, Win XP, and system 5.11 release FP1 with the Dialogic patch installed. I call the IVR, it answers and nothing else happens. The event trace log shows the following: 162842.15 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range 162934.52 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range 163644.14 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range 163719.75 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range what am I missing? Share this post Link to post
rleflore Report post Posted 05/12/2005 10:02 PM Detail trace events 165747.95 1 timer fired EV_TIMEOUT_REPLAYMSG 165747.95 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101 165747.96 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 165747.96 1 path {EV_TIMEOUT_REPLAYMSG} not found 165747.98 1 tts generate reuse 165747.98 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav) 165747.98 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav 165747.98 1 timer clear 165748.03 1 tw wav->vox convert end 377921,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,, 165748.04 1 play start ok, lPlayId=377968 165748.11 1 tw PlayEnd 1 377968 165748.11 1 play end id=377968, (current ID) 165748.11 1 event EV_PLAY_FINISHED, code=8001, state=1100 165748.12 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 165748.12 1 path {EV_PLAY_FINISHED} not found 165748.12 1 timer set 10 EV_TIMEOUT_HANGUP 165748.12 1 timer set 10 EV_TIMEOUT_HANGUP 165748.14 1 tw DialogicEvent 129,TDX_PLAY,377968,0,0,,, 165748.14 1 event TDX_PLAY, code=129, state=1101 165748.14 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 165748.14 1 path {TDX_PLAY} not found 165758.90 1 timer fired EV_TIMEOUT_HANGUP 165758.90 1 event EV_TIMEOUT_HANGUP, code=9001, state=1101 165758.90 1 LsPlayMsgFinished EV_TIMEOUT_HANGUP,EV_TIMEOUT_HANGUP 165758.90 1 path {EV_TIMEOUT_HANGUP} not found 165758.92 1 rv add [Hangup Time]{5/12/2005 4:57:58 PM} 165758.92 1 state Hanging up call... 165758.92 1 HangupCall_Common hCall=1 165758.93 1 rec RecSoundStop ok 165758.93 1 play PlaySoundStop ok 165758.93 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 165758.95 1 fnHangupCall end 165758.98 1 event callstate IDLE 1 0 0 165758.00 1 WorkingMode@Idle= 165758.00 1 timer clear 165758.00 1 rec RecSoundStop ok 165759.01 1 play PlaySoundStop ok 165759.01 1 rv add [CallEndTime]{5/12/2005 4:57:59 PM} 165759.03 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 165759.03 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 165759.03 1 event TDX_SETHOOK, code=135, state=900 165759.04 1 LsAwaitingCalls EV_UNKNOWN_135 165800.03 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 165800.03 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 165800.03 1 init atidle reinit : start 165800.05 1 init atidle reinit iConferenceOtherLegLid=-1 165800.05 1 init atidle reinit : reset all LineState variables 165800.05 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 165800.05 1 state Waiting for a call... 165800.39 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 165800.39 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 165810.53 1 event callstate OFFERING 1 0 0 165810.54 1 script interpretor: VgMulti v6.0.2000 165810.54 1 ERROR 6.0.2000 TW__LineEvCallState_Error:Subscript out of range 165810.56 1 tw ring 1 165810.56 1 ring time since last ring (ms): 0 165810.56 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 165810.57 1 event TDX_CST, code=134, state=900 165810.57 1 LsAwaitingCalls EV_UNKNOWN_134 165816.55 1 tw ring 2 165816.57 1 ring time since last ring (ms): 6.007813 165816.57 1 ring match against loaded ring patterns 165816.57 1 rv clear all 165816.58 1 init LineState ResetAtStartOfNewCall. 165816.58 1 answer the call 165816.58 1 timer clear 165816.60 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 165816.60 1 event TDX_CST, code=134, state=6001 165817.13 1 event callstate CONNECTED 1 0 0 165817.14 1 WorkingModes tapi= script= 165817.14 1 Inband detection not enabled 165817.14 1 StartLoadedVgs at 5/12/2005 4:58:17 PM 165817.16 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState 165817.16 1 set sScriptToRunOnHangup=[] in StartLoadedVgs 165817.16 1 rv add [$RV_STARTTIME]{5/12/2005 4:58:17 PM} 165817.17 1 rv add [$RV_DEVICEID]{1} 165817.17 1 rv add [$RV_CIDNAME]{} 165817.17 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 165817.19 1 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\IVRjobapp\} 165817.19 1 rv add [$RV_CIDNUMBER]{} 165817.19 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 165817.20 1 event TDX_SETHOOK, code=135, state=6001 165817.20 1 tw DialogicEvent 134,TDX_CST,1833,0,0,DE_LCON,, 165817.20 1 event TDX_CST, code=134, state=6001 165817.22 1 timer clear 165817.22 1 state [Play Introduction] Playing 165817.23 1 tts generate start[if you want to apply for job with MB then please press or say one or if you do not want to apply for a position and only wish to check on the status of an application please press two. To exit press the pound key.] 165817.25 1 tts generate wait 165817.33 1 tts generate finish 165817.33 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav) 165817.34 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav 165817.34 1 timer clear 165817.38 1 tw wav->vox convert end 407609,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,, 165817.39 1 play start ok, lPlayId=407640 165817.45 1 tw PlayEnd 1 407640 165817.45 1 play end id=407640, (current ID) 165817.47 1 event EV_PLAY_FINISHED, code=8001, state=1100 165817.47 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 165817.47 1 path {EV_PLAY_FINISHED} not found 165817.48 1 timer set 5 EV_TIMEOUT_REPLAYMSG 165817.48 1 tw DialogicEvent 129,TDX_PLAY,407640,0,0,,, 165817.48 1 event TDX_PLAY, code=129, state=1101 165817.50 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 165817.50 1 path {TDX_PLAY} not found 165822.87 1 timer fired EV_TIMEOUT_REPLAYMSG 165822.87 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101 165822.87 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 165822.89 1 path {EV_TIMEOUT_REPLAYMSG} not found 165822.89 1 tts generate reuse 165822.89 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav) 165822.90 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav 165822.90 1 timer clear 165822.93 1 tw wav->vox convert end 413203,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,, 165822.95 1 play start ok, lPlayId=413234 165823.03 1 tw PlayEnd 1 413234 165823.03 1 play end id=413234, (current ID) 165823.04 1 event EV_PLAY_FINISHED, code=8001, state=1100 165823.04 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 165823.04 1 path {EV_PLAY_FINISHED} not found 165823.06 1 timer set 5 EV_TIMEOUT_REPLAYMSG 165823.06 1 tw DialogicEvent 129,TDX_PLAY,413234,0,0,,, 165823.06 1 event TDX_PLAY, code=129, state=1101 165823.07 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 165823.07 1 path {TDX_PLAY} not found 165828.45 1 timer fired EV_TIMEOUT_REPLAYMSG 165828.45 1 event EV_TIMEOUT_REPLAYMSG, code=9005, state=1101 165828.45 1 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 165828.46 1 path {EV_TIMEOUT_REPLAYMSG} not found 165828.46 1 tts generate reuse 165828.46 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav) 165828.48 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav 165828.48 1 timer clear 165828.49 1 tw wav->vox convert end 418812,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,, 165828.51 1 play start ok, lPlayId=418828 165828.59 1 tw PlayEnd 1 418828 165828.59 1 play end id=418828, (current ID) 165828.59 1 event EV_PLAY_FINISHED, code=8001, state=1100 165828.60 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 165828.60 1 path {EV_PLAY_FINISHED} not found 165828.60 1 timer set 10 EV_TIMEOUT_HANGUP 165828.62 1 timer set 10 EV_TIMEOUT_HANGUP 165828.62 1 tw DialogicEvent 129,TDX_PLAY,418828,0,0,,, 165828.62 1 event TDX_PLAY, code=129, state=1101 165828.63 1 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 165828.63 1 path {TDX_PLAY} not found 165839.46 1 timer fired EV_TIMEOUT_HANGUP 165839.46 1 event EV_TIMEOUT_HANGUP, code=9001, state=1101 165839.46 1 LsPlayMsgFinished EV_TIMEOUT_HANGUP,EV_TIMEOUT_HANGUP 165839.47 1 path {EV_TIMEOUT_HANGUP} not found 165839.47 1 rv add [Hangup Time]{5/12/2005 4:58:39 PM} 165839.47 1 state Hanging up call... 165839.49 1 HangupCall_Common hCall=1 165839.49 1 rec RecSoundStop ok 165839.50 1 play PlaySoundStop ok 165839.50 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 165839.50 1 fnHangupCall end 165839.55 1 event callstate IDLE 1 0 0 165839.55 1 WorkingMode@Idle= 165839.57 1 timer clear 165839.57 1 rec RecSoundStop ok 165839.58 1 play PlaySoundStop ok 165839.58 1 rv add [CallEndTime]{5/12/2005 4:58:39 PM} 165839.60 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 165839.60 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 165839.60 1 event TDX_SETHOOK, code=135, state=900 165839.61 1 LsAwaitingCalls EV_UNKNOWN_135 165840.61 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 165840.61 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 165840.61 1 init atidle reinit : start 165840.62 1 init atidle reinit iConferenceOtherLegLid=-1 165840.62 1 init atidle reinit : reset all LineState variables 165840.62 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 165840.64 1 state Waiting for a call... 165840.96 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 165840.96 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 Share this post Link to post
SupportTeam Report post Posted 05/12/2005 11:22 PM It looks like the TTS is not generating any sound. Best to probably try re-installing the TTS. Which TTS are you using? To confirm if TTS is working see what is in file C:\Program Files\VoiceGuide\data\tts1.wav - that's the file into which the TTS system saved it's TTS converted sound and that's the file which VG then played.. Quote 165817.22 1 state [Play Introduction] Playing 165817.23 1 tts generate start[if you want to apply for job with MB then please press or say one or if you do not want to apply for a position and only wish to check on the status of an application please press two. To exit press the pound key.] 165817.25 1 tts generate wait 165817.33 1 tts generate finish 165817.33 1 state [Play Introduction] Playing (C:\Program Files\VoiceGuide\data\tts1.wav) 165817.34 1 tw ConvertWav2Vox C:\Program Files\VoiceGuide\data\tts1.wav 165817.34 1 timer clear 165817.38 1 tw wav->vox convert end 407609,C:\Program Files\VoiceGuide\data\tts1.vox,1,0,, 165817.39 1 play start ok, lPlayId=407640 165817.45 1 tw PlayEnd 1 407640 165817.45 1 play end id=407640, (current ID) 165817.47 1 event EV_PLAY_FINISHED, code=8001, state=1100 165817.47 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 165817.47 1 path {EV_PLAY_FINISHED} not found 165817.48 1 timer set 5 EV_TIMEOUT_REPLAYMSG 165817.48 1 tw DialogicEvent 129,TDX_PLAY,407640,0,0,,, 165817.48 1 event TDX_PLAY, code=129, state=1101 Share this post Link to post
rleflore Report post Posted 05/13/2005 02:42 PM I'm using the standard Microsoft SAPI 5. Is there some configuration that has to be done to make it work with VG? I'm only using it until I get the ATT natural voices. I assumed that once I installed the SAPI 5 for Microsoft that it would work. What else is needed? Does the VG recognize that the TTS is installed automatically? Share this post Link to post
rleflore Report post Posted 05/13/2005 05:18 PM Do I need to install Visual Basic as well? Share this post Link to post
SupportTeam Report post Posted 05/13/2005 10:53 PM Quote Is there some configuration that has to be done to make it work with VG? Can you use demo tools that came with the TTS to play text over your speakers? have you used anything else to confirm that TTS works? Best to just try re-installing it. Quote Does the VG recognize that the TTS is installed automatically? Yes. Quote Do I need to install Visual Basic as well? No. Share this post Link to post
rleflore Report post Posted 05/13/2005 10:55 PM I have re-installed the Microsoft SPEECH SDK and the VG is working properly. Thanks for your excellent support! Share this post Link to post
