Guest George Samary Report post Posted 05/23/2003 08:30 PM I'm testing your software version 4.9. I need to have a script that first transfer the call, if it detects a busy signal then it returns the call to the voice card and try another extension. I've already tried blind transfer and announced transfer but I couldn't detect the busy signal. Te script I wrote first tried one extension that I left off hook intentionaly, and on fail it would try another extension. I did not work as expected. So every time it calls the busy extension, it starts over the inicial prompts as it were a new call. I'm using a Proline 2/V with TAPI drivers. Share this post Link to post
SupportTeam Report post Posted 05/24/2003 03:14 AM Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Guest George Samary Report post Posted 05/26/2003 08:36 PM Here is the copy of the trace log. 35676 6 tapie linedevstate 2048 0 0 35736 6 tapie callstate OFFERING 66167 0 4 35756 6 Answer the call 35786 6 lineAnswer(66167) => 66150 35796 6 tapie callinfo CALLEDID 35796 6 tapie callinfo ORIGIN 35796 6 tapie ring 0 36347 6 tapie callstate CONNECTED 66167,1,0 36357 6 WorkingModeTAPI= 36357 6 WorkingModeScript= 36397 6 Inband detection not enabled 36437 6 tapi Reply 66150 0 36447 6 [Get Numbers 2] Number Input 36457 6 [Get Numbers 2] Playing (C:\Arquivos de programas\VoiceGuide\Scripts\Voicemail Server\VmbWelcomeMsgDefault.wav) 37869 6 PlaySoundStart ok [C:\Arquivos de programas\VoiceGuide\Scripts\Voicemail Server\VmbWelcomeMsgDefault.wav] 39151 6 tapie monitordigits 49 2 39151 6 LsGetNbrsPlayWelcMsg [1] 39211 6 PlaySoundStop ok 39211 6 [Get Numbers 2] Number Input 1 39221 6 LsGetNbrsRxDigits [#] 39652 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 39662 6 [Transfer Call 1] Announced Transfer to 145 (Generate) 39732 6 tapic lineGenerateDigits(66167,!) => 0 40072 6 tapie generate LINEGENERATETERM_DONE 41034 6 LsXferStart EV_TAPI_GENERATE 42045 6 LsXferPlayVts EV_HOOKFLASHFINISHED 42065 6 tapic lineGenerateDigits(66167,145) => 0 42496 6 tapie generate LINEGENERATETERM_DONE 43467 6 LsXferPlayVts EV_TAPI_GENERATE 43467 6 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 43588 6 twcal PlaySayNumber C:\Arquivos de programas\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Arquivos de programas\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 43748 6 PlaySoundStartNumbers ok 46402 6 tapie callstate DISCONNECTED 66167,0,0 46402 6 LsXferPlayAnn EV_REMOTEPARTY_DISCONNECT 46462 6 PlaySoundStop ok 47373 6 LsXferPlayAnn EV_PLAY_FINISHED 47413 6 tapic lineGenerateDigits(66167,!) => LINEERR_INVALCALLSTATE [8000001C] 47413 6 HangupCall called from [vbtapi] 47423 6 Hanging up call... 47423 6 PlaySoundStop ok 47433 6 fnHangupCall end 47473 6 tapie linedevstate 2048 0 0 47483 6 tapie callstate IDLE 66167 0 0 47493 6 WorkingMode@Idle= 47743 6 set EV_TIMEOUT_TIMETOREINITLINE 2 47743 6 tapi Reply 66082 0 48655 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 48665 6 ReinitTelephony due to IDLE start 48675 6 tapic lineDeallocateCall(MainCall:66167) 0 49316 6 lineOpen(6) => 0 49316 6 Waiting for a call... 49326 6 lineOpen(6)LineHandle=66065 Share this post Link to post
Guest George Samary Report post Posted 05/27/2003 03:15 PM I've found a solution to the problem described above. The transfered_announced_declined parameter had to be changed to &,*0 - Its a Siemens HICOM 150. Share this post Link to post
Toreandre Report post Posted 03/10/2005 03:03 PM Hi all, I have the same trouble posted here. But i can't do that " The transfered_announced_declined parameter had to be changed to &,*0 - Its a Siemens HICOM 150. " , because I have a panasonic Kx - TDA 30 and I tried to see the transfered_announced_declined in the 'vg.ini' and I can't find that. Sincerly Davide Germoni Share this post Link to post
SupportTeam Report post Posted 03/10/2005 10:08 PM What keypresses would you use on your PBX to retrieve a call? Have you tried setting that keypress in the PBX configuration? Which version of VG are you using? Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going on. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well. Share this post Link to post
