sthibodeau Report post Posted 05/24/2003 02:07 AM I have the ENterprise version of VG and I am running everything in TTS mode. WHen a caller calls the sytem answers and immedialey hangs up. BTW - I am using a dialogic card and tested the card using the dialogic utilities and everyting is working perfectly. I see in the log that it is some Wave driver issue, as mentioned that this script is 100% TTS so i am not sure hoe to reslove it! haere is the log: 38578 5 tapie linedevstate 2048 0 0 38609 5 tapie callstate OFFERING 65672 0 4 38625 5 Answer the call 38625 5 lineAnswer(65672) => 65655 38625 5 Lev_CallerID [13103086400,] 38703 5 tapie callinfo CALLEDID 38703 5 tapie callinfo ORIGIN 38703 5 tapie ring 0 39156 5 tapie callstate CONNECTED 65672,1,0 39171 5 WorkingModeTAPI= 39171 5 WorkingModeScript= 39203 5 Inband detection not enabled 39203 5 tapi Reply 65655 0 39203 5 [Greeting] Playing 39218 5 tts generate start[Welcome to Free X TV. To suscribe to this adult network please press 1. To purchase pay per view events please press 2. If you need to speak with customer service please press 3. Please make your choice now.] 40234 5 tts generate end 40234 5 [Greeting] Playing (D:\Program Files\VoiceGuide\system\tts5.wav) 40281 5 Play Start line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x2658c50, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[D:\Program Files\VoiceGuide\system\tts5.wav] 40281 5 PlaySoundStart line[5] err=[0 wavec waveOutOpen(0x0, 0x0, 0x2658c50, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [D:\Program Files\VoiceGuide\system\voicedlgc\ErrorPlayingFile.wav] 40281 5 For Dialogic use: PCM 11Khz 8bit Mono 40296 5 HangupCall called from [srlib 609] 40296 5 Hanging up call... 40296 5 PlaySoundStop ok 40296 5 fnHangupCall end 40312 5 RunModule PLAY end 41187 5 tapie linedevstate 2048 0 0 41203 5 tapie callstate IDLE 65672 0 0 41203 5 WorkingMode@Idle= 41218 5 set EV_TIMEOUT_TIMETOREINITLINE 2 41218 5 tapi Reply 65638 0 42281 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 42281 5 ReinitTelephony due to IDLE start 42281 5 tapic lineDeallocateCall(MainCall:65672) 0 42437 5 lineOpen(5) => 0 42437 5 Waiting for a call... 42437 5 lineOpen(5)LineHandle=65621 Please let me know thanks Share this post Link to post
SupportTeam Report post Posted 05/24/2003 02:50 AM Have you installed the Dialogic card's Wave drivers as per the instructions in the VoiceGuide help file? When testing the Dialogic card's TAPI/Wave drivers you need to use the TALKER32 demo program - that is the only Dialogic test program which uses the TAPI/Wave drivers. As another test can you try running a script which upon answering plays one of the WAV files in VoiceGuide's SYSTE/VOICEDLGC directory and see if that file plays OK... Share this post Link to post
