Dialer Problem
makes the call and to first stamped it begins to execute script. It does not hope that across it answers to him. It assumes that already I answer a human. That I can do?
222157,66 6 dial
[4806,096113644,505152221,1,2359,MoTuWeThFrSaSu,,2,NONE,D:\Program
Files\VoiceGuide\Scripts\Credit Card Payment\Credit Card
Payment.vgs,NONE,none,60,2,120,,none]
222157,66 0 dial callque update id=4806 next call time 0505160021
222157,67 0 dial callque DB update returned
222157,67 6 dial found entry: tel[096113644] ann[NONE] vgs[D:\Program
Files\VoiceGuide\Scripts\Credit Card Payment\Credit Card Payment.vgs]
am[NONE]
222157,67 6 Dialing: 096113644
222157,67 6 MakeCall => 66343
222157,67 6 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
222157,67 6 TapiCbTrigSet 66343 7002
222157,67 6 tapi Reply (LineEvReply) ok 66343 0
222157,67 6 TapiCbTrigClear
222157,67 6 callstate DIALING 66258 0 0
222157,67 6 callstate PROCEEDING 66258 0 0
222203,30 6 callstate CONNECTED 66258,0,0
222203,30 6 WorkingModeTAPI@Connected=
222203,30 6 WorkingModeScript@Connected=
222203,30 6 rv add [OutDial_RetriesLeft]{2}
222203,31 6 rv add [$RV_STARTTIME]{15/05/2005 22:22:03}
222203,31 6 rv add [$RV_DEVICEID]{6}
222203,31 6 rv add [$RV_CIDNAME]{}
222203,33 6 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
222203,33 6 rv add [$RV_CALLEDNUMBER]{096113644}
222203,33 6 Dialing: Playing introduction message
222203,34 6 StartLoadedVgs at 15/05/2005 22:22:03
222203,34 6 rv add [OutDial_RetriesLeft]{2}
222203,34 6 rv add [$RV_STARTTIME]{15/05/2005 22:22:03}
222203,34 6 rv add [$RV_DEVICEID]{6}
222203,36 6 rv add [$RV_CIDNAME]{}
222203,36 6 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
222203,36 6 rv add [$RV_CALLEDNUMBER]{096113644}
222203,38 6 TimeoutClear
222203,38 6 [Get Client ID] Number Input
222203,39 6 [Get Client ID] Playing (PayGetId.wav)
222203,45 6 PlaySoundStart ok [D:\Program Files\VoiceGuide\Scripts\Credit
Card Payment\PayGetId.wav]
222203,45 6 TimeoutClear
222203,47 0 dial callque delete id=4806
222203,47 6 AddRVns [OutDial_Result]{Contacted_Human}
222203,48 6 wa(8358,88615600)
222211,83 6 Play End line[6] (id=886156)
222211,84 6 ScriptEventCode 8001 iLineState=1300
222211,84 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
222211,84 6 TimeoutSet 10 EV_TIMEOUT_HANGUP
222211,86 6 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
222218,36 6 Timer fired EV_TIMEOUT_ENTERDATA
222218,36 6 ScriptEventCode 9006 iLineState=1301
222218,36 6 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
222218,36 6 rv add [Get Client ID]{}
222218,38 6 AddRVns [Get Client ID_PathTaken]{fail}
222218,38 6 rv add [Hangup Time]{15/05/2005 22:22:18}
222218,38 6 Hanging up call... [No data entered]
222218,39 6 RecSoundStop ok
222218,39 6 PlaySoundStop err=0
222218,39 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
222218,41 6 fnHangupCall end
222218,50 6 callstate DISCONNECTED 66258,1,0
222218,50 6 ScriptEventCode 9250 iLineState=900
222218,50 6 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
222218,50 6 rv add [Hangup Time]{15/05/2005 22:22:18}
222218,52 6 Hanging up call...
222218,52 6 RecSoundStop ok
222218,52 6 PlaySoundStop err=0
222218,53 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
222218,53 6 fnHangupCall end
222218,53 6 callstate IDLE 66258 0 0
222218,55 6 WorkingMode@Idle=
222218,55 6 TimeoutClear
222218,55 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
222218,56 6 tapi Reply (LineEvReply) ok 66394 0
222218,56 6 tapi Reply (LineEvReply) ok 66241 0
222219,55 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
222219,55 6 ScriptEventCode 9008 iLineState=900
222219,55 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
222219,55 6 ReinitTelephony due to IDLE
222219,56 6 tapic lineDeallocateCall(MainCall:66258) 0
222219,61 6 lineOpen(6)=>
222219,61 6 Waiting for a call...
222219,63 6 LineHandle=66462
222219,63 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
222222,91 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
222222,91 6 ScriptEventCode 9013 iLineState=900
If you set the "Annnounce Message" to "NONE" then that's how it will function. See: http://www.voiceguide.com/vghelp/html/DialListInto.htm
sAnnounceMessage
The sound file which will be played asking the recipient to accept the call if we are using a Voice modem to place calls. If the word none is specified, then no file will be played, and the strOnHuman setting will be started immediately. The full path to this sound file must be specified.  If this setting is blank or is omitted then VoiceGuide's default sound file will be used.
