Tts Not Working With Dialogic Card
I'm getting errors on the TTS msgs, but numbers are said correctly. Also if I open the TTS file in windows it plays correctly. Test 123 = "test one hundred twenty three".
I belive the problem is in the output format of the TTS wav file. It does not seam to comply withe the requirements for this old dialogic 4port ISA board.
I've attached a zip file of the script, logs, voice prompts and RunStmt.cmd file we're using for testing.
Thank you,
Amir.
CFG.zip
Use VoiceGuide for Dialogic - it will resolve the TTS problems with the older Dialogic (D/21D, D/41D, Dialog/4, VFX/40 series etc) cards.
