pedgarhi Report post Posted 05/18/2005 05:18 PM Hello. I'm working with VG for Dialogic (6.0.1055 enterprise version). My problem is that I'm receiving a BUSY event in the middle of my script that hangs up the call. I'm not trying to make a call transfer but just playing a sound file so, why am I receiving this event? You can see it in the attached file. Thanks. 0518vgm__busy_.txt Share this post Link to post
SupportTeam Report post Posted 05/18/2005 10:36 PM Have you set the busy tone description (ConfigLine.xml file) to closely match the busy tone that is played on your system? The idea is no to have too large cadence or frequency variations specified as then you are opening yourself to false busy detections. Please post the ConfigLine.xml file that is on your system now. Share this post Link to post
pedgarhi Report post Posted 05/19/2005 06:30 AM This is the configLine.xml that is on my system now. This is the default file. I haven't modified it. <?xml version="1.0" encoding="iso-8859-1"?> <Tones> <Notes> **************************************************************************** The following tone IDs should be defined: TID_DIAL_LCL TID_DIAL_INTL TID_DIAL_XTRA TID_BUSY1 TID_RNGBK1 TID_BUSY2 TID_RNGBK2 TID_DISCONNECT TID_FAX1 TID_FAX2 Omitting any defintions results in the Dialogic card using the default settings during outgoing call preogress and also the tones will not be detected during the course of the call. **************************************************************************** </Notes> <Tone Name="Call Progress Tone TID_BUSY1"> <Notes>Default Setting</Notes> <ID>TID_BUSY1</ID> <Freq1>500</Freq1> <Freq1Dev>200</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>55</On> <OnDev>40</OnDev> <Off>55</Off> <OffDev>40</OffDev> <Count>4</Count> </Tone> <Tone Name="Call Progress Tone TID_BUSY2"> <Notes>Default Setting</Notes> <ID>TID_BUSY2</ID> <Freq1>500</Freq1> <Freq1Dev>200</Freq1Dev> <Freq2>525</Freq2> <Freq2Dev>175</Freq2Dev> <On>55</On> <OnDev>40</OnDev> <Off>55</Off> <OffDev>40</OffDev> <Count>4</Count> </Tone> <Tone Name="Call Progress Tone TID_DIAL_LCL"> <Notes>Default Setting</Notes> <ID>TID_DIAL_LCL</ID> <Freq1>340</Freq1> <Freq1Dev>40</Freq1Dev> <Freq2>440</Freq2> <Freq2Dev>40</Freq2Dev> <On>100</On> <OnDev>0</OnDev> <Off>0</Off> <OffDev>0</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_DIAL_INTL"> <Notes>Default Setting</Notes> <ID>TID_DIAL_INTL</ID> <Freq1>340</Freq1> <Freq1Dev>40</Freq1Dev> <Freq2>440</Freq2> <Freq2Dev>40</Freq2Dev> <On>100</On> <OnDev>0</OnDev> <Off>0</Off> <OffDev>0</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_DIAL_XTRA"> <Notes>Default Setting</Notes> <ID>TID_DIAL_XTRA</ID> <Freq1>340</Freq1> <Freq1Dev>40</Freq1Dev> <Freq2>440</Freq2> <Freq2Dev>40</Freq2Dev> <On>100</On> <OnDev>0</OnDev> <Off>0</Off> <OffDev>0</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_DISCONNECT"> <Notes>Default Setting</Notes> <ID>TID_DISCONNECT</ID> <Freq1>500</Freq1> <Freq1Dev>200</Freq1Dev> <Freq2>525</Freq2> <Freq2Dev>175</Freq2Dev> <On>55</On> <OnDev>40</OnDev> <Off>55</Off> <OffDev>40</OffDev> <Count>4</Count> </Tone> <Tone Name="Call Progress Tone TID_FAX1"> <Notes>Default Setting</Notes> <ID>TID_FAX1</ID> <Freq1>2150</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>25</On> <OnDev>25</OnDev> <Off>0</Off> <OffDev>0</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_FAX2"> <Notes>Default Setting</Notes> <ID>TID_FAX2</ID> <Freq1>1100</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>25</On> <OnDev>25</OnDev> <Off>0</Off> <OffDev>0</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_RNGBK1"> <Notes>Ringback 1 Default Setting</Notes> <ID>TID_RNGBK1</ID> <Freq1>438</Freq1> <Freq1Dev>138</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>130</On> <OnDev>105</OnDev> <Off>400</Off> <OffDev>200</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_RNGBK2"> <Notes>Ringback 2 Default Setting</Notes> <ID>TID_RNGBK2</ID> <Freq1>438</Freq1> <Freq1Dev>138</Freq1Dev> <Freq2>438</Freq2> <Freq2Dev>138</Freq2Dev> <On>130</On> <OnDev>105</OnDev> <Off>400</Off> <OffDev>200</OffDev> <Count>1</Count> </Tone> <Notes> ***************************************************** Any extra tones can be defined now. The ID of any extra tones defined below is not to begin with the "TID_" prefix and each must have a unique ID name ***************************************************** </Notes> <Tone Name="DISCONNECT sent by PBX"> <Notes>Disconnect tone on china chepo PBX</Notes> <ID>DISCONNECT_PBX</ID> <Freq1>500</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>47</On> <OnDev>5</OnDev> <Off>47</Off> <OffDev>5</OffDev> <Count>2</Count> </Tone> <Tone Name="DISCONNECT set by TElstra"> <Notes>Telstra's disconnect tone</Notes> <ID>DISCONNECT_Telstra</ID> <Freq1>425</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>37</On> <OnDev>5</OnDev> <Off>37</Off> <OffDev>5</OffDev> <Count>2</Count> </Tone> </Tones> <Parms> <SetParm> <Description>Number of rings to wait before returning a ring event</Description> <Notes></Notes> <Key>DXCH_RINGCNT</Key> <Value>1</Value> <Default>1</Default> </SetParm> <SetParm> <Description>Enable CallerID for the channel</Description> <Notes> DX_CALLIDDISABLE 0x0000 // Disable Caller ID DX_CALLIDENABLE 0x0001 // Enable Caller ID </Notes> <Key>DXCH_CALLID</Key> <Value>1</Value> <Default>1</Default> </SetParm> <SetParm> <Description>Play rate</Description> <Notes></Notes> <Key>DXCH_PLAYRDRATE</Key> <Value>8000</Value> <Default>8000</Default> </SetParm> <SetParm> <Description>Record rate</Description> <Notes></Notes> <Key>DXCH_RECRDRATE</Key> <Value>8000</Value> <Default>8000</Default> </SetParm> </Parms> Share this post Link to post
SupportTeam Report post Posted 05/19/2005 07:55 AM The default frequencies and cadences (timings) are very broad. You will need to find out what busy tone is played on your system and alter the ConfigLine.xml TID_BUSY1 and TID_BUSY2 entries accordingly. Use Audacity from http://audacity.sourceforge.net/ to find out frequencies and cadences. Share this post Link to post
pedgarhi Report post Posted 06/28/2005 12:54 PM I have configured the following BUSY tones in the configLine.xml file: <Tone Name="Call Progress Tone TID_BUSY1"> <Notes>Default Setting</Notes> <ID>TID_BUSY1</ID> <Freq1>433</Freq1> <Freq1Dev>30</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>22</On> <OnDev>4</OnDev> <Off>22</Off> <OffDev>4</OffDev> <Count>1</Count> </Tone> <Tone Name="Call Progress Tone TID_BUSY2"> <Notes>Default Setting</Notes> <ID>TID_BUSY2</ID> <Freq1>433</Freq1> <Freq1Dev>30</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>22</On> <OnDev>4</OnDev> <Off>22</Off> <OffDev>4</OffDev> <Count>2</Count> </Tone> and I have updated my system to version VG for Dialogic 6.0.2028, but I sometimes receive a BUSY event that hangs up the call (as shown in the trace). 0628vgm__busy_tone_hangs_up_.txt Share this post Link to post
SupportTeam Report post Posted 06/28/2005 01:27 PM Trace shows TID_BUSY1 was detected. Not surprising really as it's <Count> field is set to 1. Best to change the <Count> field on both busy tones to 3 or higher. Share this post Link to post
