Cannot Get Data From Text File
I am not so familiar with vb script and voiceguide, please help me a little bit please.
in run vbscrip:
set fso = CreateObject("Scripting.FileSystemObject")
set fileVmBoxList = fso.OpenTextFile("C:\CurrentPrices.txt")
sEntireFile = fileVmBoxList.ReadAll
set fileVmBoxList = Nothing
set fso = Nothing
vg.RvSet $RV_LINEID, "data", sEntireFile
set vg = Nothing
in evaluate expression module
$rv[data]
on {abc} goto [Play 1]
on {def} goto [Play 2]
I find that there is not thing in $rv[data], what wrong with my setting. Would you mind helping me in this, thank you very much
Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is going wrong.
When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.
You can enable the automatic saving of the logs to files in \log\ directory as well.
Thanks for your quick reply!!
Here are the log:
104221.79 5 linedevstate 2048 0 0
104221.79 5 callstate OFFERING 66212 0 4
104221.79 5 rv clear
104221.79 5 Answer the call at 5/20/2005 10:42:21 AM
104221.79 5 lineAnswer(66212) => 66263
104221.79 5 callinfo CALLEDID
104221.79 5 callinfo ORIGIN
104221.80 5 ring 0
104222.32 5 callstate CONNECTED 66212 1 0
104222.32 5 callstate CONNECTED 66212,1,0
104222.32 5 WorkingModeTAPI@Connected=
104222.34 5 WorkingModeScript@Connected=
104222.34 5 Inband detection not enabled
104222.35 5 StartLoadedVgs at 5/20/2005 10:42:22 AM, v5.2.3063
104222.35 5 AddRVns [scriptsPath]{D:\Local_Server\Voice_guide_script\}
104222.35 5 AddRVns [scriptPath]{D:\Local_Server\Voice_guide_script}
104222.35 5 rv add [$RV_STARTTIME]{5/20/2005 10:42:22 AM}
104222.35 5 rv add [$RV_DEVICEID]{5}
104222.37 5 rv add [$RV_CIDNAME]{}
104222.37 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
104222.41 5 rv add [$RV_CIDNUMBER]{}
104222.45 5 tapi Reply (LineEvReply) ok 66263 0
104222.48 5 callinfo MONITORMODES
104222.52 0 dial start any summary:|5:hc>0|6:idx=0|
104222.57 5 timer clear
104222.60 5 [Run VB Script 1] Running VB Script...
104222.63 5 rv replace start: [set fso = CreateObject("Scripting.FileSystemObject")
set fso = Nothing
set vg = Nothing
104222.66 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Local_Server\Voice_guide_script\}[scriptPath]{D:\Local_Server\Voice_guide_script}[$RV_STARTTIME]{5/20/2005 10:42:22 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}
104222.70 5 eng run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_5_1.vbs" //I] copy of script in: vbs_5_1.vbs
104222.74 5 Run Script waiting. iRunWait=1 (shellid=616, process=1320)
104222.77 5 timer set 1 EV_TIMEOUT_CHECKONSTATE
104222.80 5 cl RvSet data, abc
104222.85 5 ERROR: COM interface not supported in this version.
104223.79 5 timer fired EV_TIMEOUT_CHECKONSTATE
104223.82 5 ScriptEventCode 9007 iLineState=1501
104223.85 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
104223.88 5 task completed (shellid=616, process=1320) vgm=1, iRunWait=1, iRunWait_ExeResult_NextVgm=0
104223.93 5 No information returned from program to VG (no VGRUNRESULT_5.TXT or SHLRESLT.TXT)
104223.96 5 rv add [Hangup Time]{5/20/2005 10:42:23 AM}
104223.99 5 Hanging up call... [WaitTillFinished - next module not specified]
104224.02 5 RecSoundStop ok
104224.07 5 PlaySoundStop err=0
104224.10 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104224.13 5 fnHangupCall end
104224.35 5 linedevstate 2048 0 0
104224.38 5 callstate IDLE 66212 0 0
104224.43 5 WorkingMode@Idle=
104224.46 5 timer clear
104224.49 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
104224.52 5 tapi Reply (LineEvReply) ok 66365 0
104225.55 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
104225.59 5 ScriptEventCode 9008 iLineState=900
104225.62 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
104225.65 5 ReinitTelephony due to IDLE
104225.70 5 tapic lineDeallocateCall(MainCall:66212) 0
104225.88 5 lineOpen(5)=>
104225.91 5 Waiting for a call...
104225.96 5 LineHandle=66314
104225.99 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
104226.70 0 dial start any summary:|5:rdy=0|6:idx=0|
104229.30 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
104229.34 5 ScriptEventCode 9013 iLineState=900
104229.73 0 dial start any summary:|5:idx=0|6:idx=0|
104303.43 0 sys cleanup Start
104303.46 0 sys cleanup End
I hope this log can help you to solve my problem.
I use Dialog D/41ESC, voice guide version is v5.2.3
Thank you very much
We can see in the trace:
the VoiceGuide.CommandLink COM interface is only supported in the Enterprise and the evaluation versions of VoiceGuide. See: http://www.voiceguide.com/vgFeatures.htm
You will need to upgrade to that version to use COM functions in your script.
Oh! I know the problem now, thank you your kind attention of my case and quick respone.
Thank you very much. It is a good support.
