Guest HHL Report post Posted 05/19/2005 09:44 AM I am not so familiar with vb script and voiceguide, please help me a little bit please. in run vbscrip: set fso = CreateObject("Scripting.FileSystemObject") set fileVmBoxList = fso.OpenTextFile("C:\CurrentPrices.txt") sEntireFile = fileVmBoxList.ReadAll set fileVmBoxList = Nothing set fso = Nothing set vg = CreateObject("VoiceGuide.CommandLink") vg.RvSet $RV_LINEID, "data", sEntireFile set vg = Nothing in evaluate expression module $rv[data] on {abc} goto [Play 1] on {def} goto [Play 2] I find that there is not thing in $rv[data], what wrong with my setting. Would you mind helping me in this, thank you very much Share this post Link to post
SupportTeam Report post Posted 05/19/2005 08:40 PM Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is going wrong. When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well. Share this post Link to post
Guest HHL Report post Posted 05/20/2005 03:04 AM Thanks for your quick reply!! Here are the log: 104221.79 5 linedevstate 2048 0 0 104221.79 5 callstate OFFERING 66212 0 4 104221.79 5 rv clear 104221.79 5 Answer the call at 5/20/2005 10:42:21 AM 104221.79 5 lineAnswer(66212) => 66263 104221.79 5 callinfo CALLEDID 104221.79 5 callinfo ORIGIN 104221.80 5 ring 0 104222.32 5 callstate CONNECTED 66212 1 0 104222.32 5 callstate CONNECTED 66212,1,0 104222.32 5 WorkingModeTAPI@Connected= 104222.34 5 WorkingModeScript@Connected= 104222.34 5 Inband detection not enabled 104222.35 5 StartLoadedVgs at 5/20/2005 10:42:22 AM, v5.2.3063 104222.35 5 AddRVns [scriptsPath]{D:\Local_Server\Voice_guide_script\} 104222.35 5 AddRVns [scriptPath]{D:\Local_Server\Voice_guide_script} 104222.35 5 rv add [$RV_STARTTIME]{5/20/2005 10:42:22 AM} 104222.35 5 rv add [$RV_DEVICEID]{5} 104222.37 5 rv add [$RV_CIDNAME]{} 104222.37 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 104222.41 5 rv add [$RV_CIDNUMBER]{} 104222.45 5 tapi Reply (LineEvReply) ok 66263 0 104222.48 5 callinfo MONITORMODES 104222.52 0 dial start any summary:|5:hc>0|6:idx=0| 104222.57 5 timer clear 104222.60 5 [Run VB Script 1] Running VB Script... 104222.63 5 rv replace start: [set fso = CreateObject("Scripting.FileSystemObject") set fileVmBoxList = fso.OpenTextFile("C:\CurrentPrices.txt") sEntireFile = fileVmBoxList.ReadAll set fileVmBoxList = Nothing set fso = Nothing set vg = CreateObject("VoiceGuide.CommandLink") vg.RvSet $RV_LINEID, "data", sEntireFile set vg = Nothing ] 104222.66 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{D:\Local_Server\Voice_guide_script\}[scriptPath]{D:\Local_Server\Voice_guide_script}[$RV_STARTTIME]{5/20/2005 10:42:22 AM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{} 104222.70 5 eng run vbs [wscript "C:\Program Files\VoiceGuide\data\vbs_5_1.vbs" //I] copy of script in: vbs_5_1.vbs 104222.74 5 Run Script waiting. iRunWait=1 (shellid=616, process=1320) 104222.77 5 timer set 1 EV_TIMEOUT_CHECKONSTATE 104222.80 5 cl RvSet data, abc 104222.85 5 ERROR: COM interface not supported in this version. 104223.79 5 timer fired EV_TIMEOUT_CHECKONSTATE 104223.82 5 ScriptEventCode 9007 iLineState=1501 104223.85 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 104223.88 5 task completed (shellid=616, process=1320) vgm=1, iRunWait=1, iRunWait_ExeResult_NextVgm=0 104223.93 5 No information returned from program to VG (no VGRUNRESULT_5.TXT or SHLRESLT.TXT) 104223.96 5 rv add [Hangup Time]{5/20/2005 10:42:23 AM} 104223.99 5 Hanging up call... [WaitTillFinished - next module not specified] 104224.02 5 RecSoundStop ok 104224.07 5 PlaySoundStop err=0 104224.10 5 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 104224.13 5 fnHangupCall end 104224.35 5 linedevstate 2048 0 0 104224.38 5 callstate IDLE 66212 0 0 104224.43 5 WorkingMode@Idle= 104224.46 5 timer clear 104224.49 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 104224.52 5 tapi Reply (LineEvReply) ok 66365 0 104225.55 5 timer fired EV_TIMEOUT_TIMETOREINITLINE 104225.59 5 ScriptEventCode 9008 iLineState=900 104225.62 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 104225.65 5 ReinitTelephony due to IDLE 104225.70 5 tapic lineDeallocateCall(MainCall:66212) 0 104225.88 5 lineOpen(5)=> 104225.91 5 Waiting for a call... 104225.96 5 LineHandle=66314 104225.99 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 104226.70 0 dial start any summary:|5:rdy=0|6:idx=0| 104229.30 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 104229.34 5 ScriptEventCode 9013 iLineState=900 104229.73 0 dial start any summary:|5:idx=0|6:idx=0| 104303.43 0 sys cleanup Start 104303.46 0 sys cleanup End I hope this log can help you to solve my problem. I use Dialog D/41ESC, voice guide version is v5.2.3 Thank you very much Share this post Link to post
SupportTeam Report post Posted 05/20/2005 03:08 AM We can see in the trace: 104222.85 5 ERROR: COM interface not supported in this version. the VoiceGuide.CommandLink COM interface is only supported in the Enterprise and the evaluation versions of VoiceGuide. See: http://www.voiceguide.com/vgFeatures.htm You will need to upgrade to that version to use COM functions in your script. Share this post Link to post
Guest HHL Report post Posted 05/20/2005 04:46 AM Oh! I know the problem now, thank you your kind attention of my case and quick respone. Thank you very much. It is a good support. Share this post Link to post
