Guest Guest_Doris Report post Posted 05/19/2005 04:04 PM Background: Win 2003 Server + Latest Voiceguide. Setting: Voiceguide runs an exe (test.exe) in a path (e.g. d:\testprogram) which will generate the result file. (i forgot the name). Symtom: when you click the exe manually, the file is generated. but it is voiceguide to trigger the exe, the file is not generated. Solution: put the program under C:\Document and Settings\Administrator (the loggined a/c). Explanation: when voice guide runs the program, its path is at C:\Document and Settings\Administrator (the path in the default command prompt). If we kept on running the program in d:\testprogram, there may be file not found or similiar problems Maybe the support team can give a better explanation. But i do think the above findings can help some of you. Share this post Link to post
SupportTeam Report post Posted 05/20/2005 12:45 AM Sounds like your test.exe program saves the result file in a 'current' directory, without specifying the path. 'Current' directory is left up to Windows to decide, so quite often files that programs ask for windows to save in a 'current' directory wind up in place other then expected.. When outputting the results file from within programs it's usually best to explicitly state the full path of the results file. We recommend using the COM function Run_ResultReturn when returning info to VoiceGuide from 3rd party programs. see: http://www.voiceguide.com/vghelp/html/com_...esultReturn.htm Share this post Link to post
