Guest Rico Report post Posted 05/26/2003 05:40 AM I am trying to test callerID feature with VG 4.9.0 using D/4PCI in Win2K pro. The setup works with my demo script. When I test callerID is seems not working. I click on the line config the popup callerID details and it displays nothing. I check on the event log and it seems no callerId data too. When I put back the CallerID device provided by my phone company and try to ring the line, caller phone is display on that unit. Is there any special steps that I need to config on VG and dialogic to make this work? Thanks for the support. Share this post Link to post
SupportTeam Report post Posted 05/26/2003 06:24 AM You will need to configure the Dialogic card to have it correctly detect the Caller ID sent by your phone company - you will need to speak to your local Intel/Dialogic rep to find out what settings and parameter files you should be using with the card in your country/location. Share this post Link to post
