Guest KB Report post Posted 05/20/2005 01:15 PM I'm using the Intel dialogic card with 4 lines, i've first tested the script with only one line and it was working but now when i've switched to 4 lines it doesn't work. It shows on the trace that it answers and plays the files but the phone keeps ringing as if there's no answer. Here's the event trace log: 140857.12 6 linedevstate 2048 0 0 140857.12 6 callstate OFFERING 65776 0 4 140857.12 6 callinfo CALLEDID 140857.12 6 callinfo ORIGIN 140857.12 6 ring 0 140857.54 0 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0| 140903.12 6 ring 2 140903.12 6 rv clear 140903.12 6 Answer the call at 20/05/2005 14:09:03 140903.14 6 lineAnswer(65776) => 65741 140903.66 6 callstate CONNECTED 65776 1 0 140903.66 6 callstate CONNECTED 65776,1,0 140903.66 6 WorkingModeTAPI@Connected= 140903.66 6 WorkingModeScript@Connected= 140903.68 6 Inband detection not enabled 140903.68 6 StartLoadedVgs at 20/05/2005 14:09:03, v5.2.3063 140903.68 6 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\BonhamsIVR\} 140903.68 6 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\BonhamsIVR} 140903.68 6 rv add [$RV_STARTTIME]{20/05/2005 14:09:03} 140903.68 6 rv add [$RV_DEVICEID]{6} 140903.70 6 rv add [$RV_CIDNAME]{} 140903.70 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 140903.70 6 rv add [$RV_CIDNUMBER]{} 140903.70 6 tapi Reply (LineEvReply) ok 65741 0 140903.70 6 timer clear 140903.70 6 [Welcome] Playing 140903.70 6 [Welcome] Playing (SoundFiles\Bonhams1.wav) 140903.71 6 play set playid=56062 140903.74 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\BonhamsIVR\SoundFiles\Bonhams1.wav] 140903.76 6 timer clear 140903.76 6 RunModule PLAY end 140903.76 6 wa(2795,5606200) 140903.76 6 callinfo MONITORMODES 140903.76 6 callinfo MONITORMODES 140906.60 6 play end current play (playid=56062) 140906.60 6 ScriptEventCode 8001 iLineState=1100 140906.62 6 LsPlayMsg EV_PLAY_FINISHED 140906.62 6 timer set 10 EV_TIMEOUT_HANGUP 140906.62 6 timer set 0 EV_TIMEOUT_GOTOMODULE 140906.62 6 ScriptEventCode 9002 iLineState=1101 140906.62 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 140906.62 6 timer clear 140906.62 6 [FaxOrResult] Playing 140906.62 6 [FaxOrResult] Playing (SoundFiles\Bonhams1a.wav) 140906.64 6 play set playid=58984 140906.64 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\BonhamsIVR\SoundFiles\Bonhams1a.wav] 140906.65 6 timer clear 140906.65 6 RunModule PLAY end 140906.65 6 wa(9635,5898400) 140906.65 6 callinfo MONITORMODES 140916.29 6 wb(5898400) 140916.34 6 play end current play (playid=58984) 140916.35 6 ScriptEventCode 8001 iLineState=1100 140916.35 6 LsPlayMsg EV_PLAY_FINISHED 140916.35 6 eng set timer EV_TIMEOUT_REPLAYMSG time=2 140916.35 6 timer set 2 EV_TIMEOUT_REPLAYMSG 140918.43 6 timer fired EV_TIMEOUT_REPLAYMSG 140918.43 6 ScriptEventCode 9005 iLineState=1101 140918.43 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 140918.43 6 [FaxOrResult] Playing (SoundFiles\Bonhams1a.wav) 140918.43 6 play set playid=70781 140918.45 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\BonhamsIVR\SoundFiles\Bonhams1a.wav] 140918.45 6 timer clear 140918.45 6 wa(9635,7078100) 140918.45 6 callinfo MONITORMODES 140928.09 6 wb(7078100) 140928.15 6 play end current play (playid=70781) 140928.15 6 ScriptEventCode 8001 iLineState=1100 140928.15 6 LsPlayMsg EV_PLAY_FINISHED 140928.15 6 timer set 10 EV_TIMEOUT_HANGUP 140928.15 6 timer set 2 EV_TIMEOUT_GOTOMODULE 140930.26 6 timer fired EV_TIMEOUT_GOTOMODULE 140930.26 6 ScriptEventCode 9002 iLineState=1101 140930.26 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 140930.26 6 timer clear 140930.26 6 rv add [Hangup Time]{20/05/2005 14:09:30} 140930.26 6 Hanging up call... [Hangup Module] 140930.26 6 RecSoundStop ok 140930.26 6 PlaySoundStop err=0 140930.27 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 140930.27 6 fnHangupCall end 140930.30 6 linedevstate 2048 0 0 140930.32 6 callstate IDLE 65776 0 0 140930.32 6 WorkingMode@Idle= 140930.32 6 timer clear 140930.32 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 140930.34 6 tapi Reply (LineEvReply) ok 65758 0 140931.37 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 140931.37 6 ScriptEventCode 9008 iLineState=900 140931.37 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 140931.37 6 ReinitTelephony due to IDLE 140931.37 6 tapic lineDeallocateCall(MainCall:65776) 0 140931.41 6 lineOpen(6)=> 140931.43 6 Waiting for a call... 140931.43 6 LineHandle=65707 140931.43 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 140932.07 0 dial start any summary:|6:rdy=0|7:idx=0|8:idx=0|9:idx=0| 140934.71 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 140934.71 6 ScriptEventCode 9013 iLineState=900 140935.12 0 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0| Thanks. Share this post Link to post
SupportTeam Report post Posted 05/20/2005 02:28 PM If the phone company's switch or PBX does not detect that the Dialogic card has answered the call then either that port on the Switch/PBX is fault or the line interface circuitry on the Dialogic card is faulty on that port... It's like picking up the handset on your phone after it rings, but the caller keeps on hearing the ringing - either the Switch/PBX is faulty or the phone is... Share this post Link to post
Guest KB Report post Posted 06/06/2005 03:35 PM Well i've change everything back to what it was with only one analog line and i still have the same problem. Do you have any other idea why this happens? do i have to re-install the voice drivers? Share this post Link to post
SupportTeam Report post Posted 06/06/2005 08:08 PM Re-installing voice drivers probably will not do much, this is a hardware level problem. Have you tried using any of the demo software which came with the card, like Talker32 or Voice Horoscope, and seeing what results you get when using those apps? Share this post Link to post
