Recommended System Requirements
Are there recommended requirements in addition to minimum requirements?
I've set it up on a Windows 2000 PC with a 1.70 GHz processor and
261 megs of RAM.
David
How many lines will you be running on this system?
So far just one. The card we have (D/4PCIUF) supports up to four
but I doubt we would need more than three.
David
What about 120 line per system ? using Intel D/MV1200-4E1, What is the minimum system requirements ?
Do you know if Dialogic boards will run under a system using an AMD Athlon CPU and Motherboard, or must they be Intel?
We currently have 3 higher-end systems (2.5MHz, 1GB Ram, etc.) running under AMD architecture and wish to use those if possible?
All of our test systems are Intel based.
We're not aware of any problems, but I suspect that if Intel were asked their answer would be that an Intel CPU based system should be used...
You can probably just try and see if it works OK...
thanx for reply .. so if I want to use VG in my system which is equiped with DM V1200 4E1 , I need to :
1- install VG software .
2- Add VG for Dialogic Patch .
3- buy 2 liscences of Entprise edition each with 60 lines .
Is that correct ? do I need any other thing ?
Regards
That's all there is to it.
Are you using E1 ISDN lines? What ISDN protocol are you using on these lines?
