Voiceguide For Dialogic?
Recently I downloaded VoiceGuide 5.2.4000 patch and I noticed that there is a download that says: "VoiceGuide for Dialogic patch v6.0.2" and a brief explanation on VG for Dailogic differences. I have 4 line license and the dialer, the question is:
is that a dialogic oriented patch that I can use on "classic" VG or is it another product that need to be purchased separatelly?
Thank you.
FM
When you buy the license you just need to specify that you are using "VG for Dialogic" and then the appropriate code is issued.
Pricing is the same as the normal version of VG.
does it only depend on the unlock code?
if true then mine should be for dialogic because this is for 4 lines. You told me that you can not use the first identifier I sent to you because it was for the hard disk... well, the question is, can I resend unique ID to you to get a code to enable this special features?
FM
Please send an email to sales@vocieguide.com along with your license/order details.
