rcioppa Report post Posted 05/27/2003 01:22 AM I've been running version 4.5.4 for about 2 years now and every once and a while when I call in to to pickup messages, I get to hear the message and when I delete or save it, I get the response "the sound file can not be found", but after I handup and call back the message was deleted and everything is fine. I saw the post of something similar, but it sounded like they wouln't even hear it for the first time. If the solution is to install version 9, how do I do the and insure I won't screw up my system that's been working for 2 years? Will I need another key, can I install it on a completely different directory so I can fall back? Are my scripts and windows2000 access SQL commands still going to work? Share this post Link to post
SupportTeam Report post Posted 05/27/2003 06:28 AM v4.5.4 scripts will work with v4.9 - no changes are necessary. If you wnat to start using v4.9 you will need to purchase an upgrade - please see our WWW based order form. Share this post Link to post
