Trigger Execution Of Another Module.
I have a script that creates new folder. Under certain conditions I want that VBScript to trigger another module withing the same VoiceGuideScript (create_newfolder.vgs).
Dim fso, newFldr, vg, fldr
Set fso = CreateObject("Scripting.FileSystemObject")
Set newFldr = "$RV[GetDigits]"
If Not fso.FolderExists("D:\" & newFldr) Then
 Set fldr = fso.CreateFolder("D:\" & newFldr)
 Set fso = Nothing
 vg.Script_Goto $RV_LINEID, "create_newfolder.vgs", "Success"
 set vg = Nothing
Else
 vg.Script_Goto $RV_LINEID, "create_newfolder.vgs", "Exists"
 set vg = Nothing
End If
The script works fine without the following code (that's the code that doesn't work):
  set vg = Nothing
My Question:
How can I trigger execution of module within the same VGscript? The code that I use right now (above), doesn't do the job. I would like to do it without using 'Path' tab.
Is my line correct?
Thank you in advance.
I also tried using:
and
vg.Run_ResultReturn $RV_LINEID, "fail"
But it also didn't help me. I am using VG version 5.2
Does the module "Success" exist?
Does the other command:
work fine for you?
You can enable the automatic saving of the logs to files in \log\ directory as well.
Thank you for asking the right questions. It took me a while to fix it (since to test it I need to use payphone), but your ideas put me in a right track.
THANK YOU for helping me.
