Problem Time Switch
Dear Support,
I have upgraded to VG for Dialogic (6.0.2). It seems that the Time Switch isn't working.
First I had a problem for giving in the correct time. Because my regional settings were set to Belgium. We don't use AM and PM so I couldn't send it to 17:00. So I changed my regional settings.
Now the time switch isn't working... Here is the log...
144802.52 2 tw ring 1
144802.52 2 ring time since last ring (ms): 0
144802.53 2 rv clear all
144802.53 2 init LineState ResetAtStartOfNewCall.
144802.54 2 answer the call
144802.54 2 timer clear
144802.56 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
144802.58 2 event TDX_CST, code=134, state=6001
144803.15 2 event callstate CONNECTED 2 0 0
144803.21 2 WorkingModes tapi= script=
144803.25 2 Inband detection not enabled
144803.33 2 StartLoadedVgs at 4/06/2005 2:48:03 PM
144803.40 2 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
144803.47 2 set sScriptToRunOnHangup=[] in StartLoadedVgs
144803.61 2 rv add [$RV_STARTTIME]{4/06/2005 2:48:03 PM}
144803.66 2 rv add [$RV_DEVICEID]{2}
144803.70 2 rv add [$RV_CIDNAME]{}
144803.73 2 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
144803.77 2 rvns add [scriptsPath]{N:\Telefooncentrale\scripts\}
144803.82 2 rv add [$RV_CIDNUMBER]{}
144803.86 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
144803.89 2 event TDX_SETHOOK, code=135, state=6001
144803.95 2 tw DialogicEvent 134,TDX_CST,1080,0,0,DE_LCON,,
144803.98 2 event TDX_CST, code=134, state=6001
144804.04 2 timer clear
144804.11 2 state [MenuKantoor@yora] Playing
144804.16 2 state [MenuKantoor@yora] Playing (N:\Telefooncentrale\yora menu gesloten.wav)
144804.22 2 tw ConvertWav2Vox N:\Telefooncentrale\yora menu gesloten.wav
144804.30 2 timer clear
144804.52 2 tw wav->vox convert end 379895,N:\Telefooncentrale\yora menu gesloten.vox,1,0,,
144804.70 2 play start ok, lPlayId=380265
Trace does not show any Time Switch module being executed...
Can you post a script which demonstrates the problem?
