Database Problem
Trying to do database query but failed. Please tell the solution.
125808.80 8 linedevstate 2048 0 0
125808.80 8 callstate OFFERING 66186 0 4
125808.80 8 Answer the call at 6/8/2005 12:58:08 PM
125808.80 8 lineAnswer(66186) => 66135
125808.80 8 callinfo CALLEDID
125808.80 8 callinfo ORIGIN
125808.80 8 ring 0
125809.34 8 callstate CONNECTED 66186 1 0
125809.34 8 callstate CONNECTED 66186,1,0
125809.34 8 WorkingModeTAPI@Connected=
125809.34 8 WorkingModeScript@Connected=
125809.36 8 Inband detection not enabled
125809.36 8 StartLoadedVgs at 6/8/2005 12:58:09 PM
125809.36 8 AddRVns [scriptsPath]{E:\Call center\}
125809.36 8 AddRVns [scriptPath]{E:\Call center}
125809.36 8 rv add [$RV_STARTTIME]{6/8/2005 12:58:09 PM}
125809.36 8 rv add [$RV_DEVICEID]{8}
125809.36 8 rv add [$RV_CIDNAME]{}
125809.36 8 AddRVns [PathApp]{D:\Program Files\VoiceGuide\}
125809.36 8 rv add [$RV_CIDNUMBER]{}
125809.36 8 tapi Reply (LineEvReply) ok 66135 0
125809.36 8 TimeoutClear
125809.36 8 [Welcome] Playing
125809.36 8 [Welcome] Playing (Welcome note.wav)
125809.36 8 play set playid=852015
125809.38 8 PlaySoundStart ok [E:\Call center\Welcome note.wav]
125809.38 8 TimeoutClear
125809.38 8 RunModule PLAY end
125809.38 8 wa(4823,85201500)
125809.38 8 callinfo MONITORMODES
125813.13 8 dtmf 1 (66186,49,2)
125813.13 8 ScriptEventCode 49 iLineState=1100
125813.13 8 LsPlayMsg 1
125813.17 8 PlaySoundStop err=0
125813.17 8 rv add [Welcome]{1}
125813.17 8 TimeoutClear
125813.17 8 [Get IDN] Number Input
125813.17 8 [Get IDN] Playing (IDN Entering.wav)
125813.17 8 play set playid=855828
125813.17 8 PlaySoundStart ok [E:\Call center\IDN Entering.wav]
125813.19 8 wa(5847,85582800)
125813.19 8 callinfo MONITORMODES
125818.80 8 dtmf 1 (66186,49,2)
125818.80 8 ScriptEventCode 49 iLineState=1300
125818.80 8 LsGetNbrsPlayWelcMsg 1
125818.84 8 PlaySoundStop err=0
125818.84 8 [Get IDN] Number Input 1
125818.84 8 path {1} not found
125818.84 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125819.63 8 dtmf 2 (66186,50,2)
125819.63 8 ScriptEventCode 50 iLineState=1301
125819.63 8 LsGetNbrsRxDigits 2
125819.63 8 [Get IDN] Number Input 12
125819.63 8 path {12} not found
125819.63 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125820.58 8 dtmf 0 (66186,48,2)
125820.58 8 ScriptEventCode 48 iLineState=1301
125820.58 8 LsGetNbrsRxDigits 0
125820.58 8 [Get IDN] Number Input 120
125820.58 8 path {120} not found
125820.58 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125821.34 8 dtmf 2 (66186,50,2)
125821.36 8 ScriptEventCode 50 iLineState=1301
125821.36 8 LsGetNbrsRxDigits 2
125821.36 8 [Get IDN] Number Input 1202
125821.36 8 path {1202} not found
125821.36 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125822.20 8 dtmf 4 (66186,52,2)
125822.20 8 ScriptEventCode 52 iLineState=1301
125822.20 8 LsGetNbrsRxDigits 4
125822.20 8 [Get IDN] Number Input 12024
125822.20 8 path {12024} not found
125822.20 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125823.03 8 dtmf 2 (66186,50,2)
125823.03 8 ScriptEventCode 50 iLineState=1301
125823.03 8 LsGetNbrsRxDigits 2
125823.03 8 [Get IDN] Number Input 120242
125823.03 8 path {120242} not found
125823.03 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125823.78 8 dtmf 2 (66186,50,2)
125823.78 8 ScriptEventCode 50 iLineState=1301
125823.78 8 LsGetNbrsRxDigits 2
125823.78 8 [Get IDN] Number Input 1202422
125823.78 8 path {1202422} not found
125823.78 8 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
125823.78 8 TimeoutClear
125823.78 8 rv add [Get IDN]{1202422}
125823.78 8 AddRVns [Get IDN_PathTaken]{success}
125823.78 8 [Check IDN] DB Query
125823.78 8 db Jet mode used (To use ODBC mode specify ODBC Connect string)
125823.80 8 rv replace start: [sELECT cs FROM idn WHERE idn = '$RV[Get IDN]']
125823.80 8 rv ns [PathSysVoice]{}[PathApp]{D:\Program Files\VoiceGuide\}[PathDataVm]{D:\Program Files\VoiceGuide\data\}[PathVgSys]{D:\Program Files\VoiceGuide\system\}[scriptsPath]{E:\Call center\}[scriptPath]{E:\Call center}[$RV_STARTTIME]{6/8/2005 12:58:09 PM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{D:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{1}[Get IDN]{1202422}[Get IDN_PathTaken]{success}
125823.81 8 rv replace end: [sELECT cs FROM idn WHERE idn = '1202422']
125823.81 8 db About to execute a Retrieve type operation [sELECT cs FROM idn WHERE idn = '1202422']
125823.84 8 OpenRecordset: 3061:Too few parameters. Expected 2.
125823.84 8 TimeoutClear
125823.84 8 [invalid IDN] Playing
125823.84 8 [invalid IDN] Playing (Invalid IDN.wav)
125823.86 8 play set playid=866515
125823.88 8 PlaySoundStart ok [E:\Call center\Invalid IDN.wav]
125823.89 8 TimeoutClear
125823.91 8 RunModule PLAY end
125823.91 8 wa(2635,86651500)
125823.92 8 callinfo MONITORMODES
125826.58 8 play end current play (playid=866515)
125826.58 8 ScriptEventCode 8001 iLineState=1100
125826.58 8 LsPlayMsg EV_PLAY_FINISHED
125826.58 8 TimeoutSet 10 EV_TIMEOUT_HANGUP
125837.48 8 Timer fired EV_TIMEOUT_HANGUP
125837.48 8 ScriptEventCode 9001 iLineState=1101
125837.48 8 LsPlayMsgFinished EV_TIMEOUT_HANGUP
125837.48 8 rv add [Hangup Time]{6/8/2005 12:58:37 PM}
125837.48 8 Hanging up call...
125837.48 8 RecSoundStop ok
125837.48 8 PlaySoundStop err=0
125837.48 8 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
125837.48 8 fnHangupCall end
125837.53 8 linedevstate 2048 0 0
125837.53 8 callstate IDLE 66186 0 0
125837.53 8 WorkingMode@Idle=
125837.53 8 TimeoutClear
125837.53 8 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
125837.53 8 tapi Reply (LineEvReply) ok 66152 0
125838.58 8 Timer fired EV_TIMEOUT_TIMETOREINITLINE
125838.58 8 ScriptEventCode 9008 iLineState=900
125838.58 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
125838.58 8 ReinitTelephony due to IDLE
125838.58 8 tapic lineDeallocateCall(MainCall:66186) 0
125838.63 8 lineOpen(8)=>
125838.63 8 Waiting for a call...
125838.63 8 LineHandle=66033
125838.63 8 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
125838.94 0 dial start any summary:|8:rdy=0|
125839.94 0 dial start any summary:|8:rdy=0|
125840.94 0 dial start any summary:|8:rdy=0|
125841.92 8 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
125841.92 8 ScriptEventCode 9013 iLineState=900
125851.70 0 sys cleanup Start
125851.70 0 sys cleanup End
Attaching the database file also, I want to select "c s" from idn table where "idn" = received dtmf tone
Database.zip
The column in database is "i d n", not "idn" - so the SQL command is wrong.
Rename "i d n" to something else - with no spaces. eg. if you were to name that column "idnumber" then the SQL would be:
SELECT cs FROM idn WHERE idnumber= '1202422'
