Guest srusse01 Report post Posted 05/28/2003 02:59 AM Please can you tell me why I am getting the above message, and what it means. The script that it came from is as follows (this program has been running for approximately 1yr now, and I have not had this problem before) 60969 5 [updateDrugIssueToStudy_ACTORDS] DB Query 60985 5 Jet mode used (To use ODBC mode specify ODBC Connect string) 61079 5 RVreplace start: [uPDATE tbl_StudyNumber SET DrugIss =$RV[GetPackNo_2_1] WHERE StudyID='$RV[GetStudyId_1_1]'] 61141 5 RVreplace end: [uPDATE tbl_StudyNumber SET DrugIss =41504 WHERE StudyID=400320] 61141 5 About to execute Action Query 61157 5 ERROR: DB Execute: 6,Overflow 61172 5 Hanging up call... Thanks Share this post Link to post
SupportTeam Report post Posted 05/28/2003 07:25 AM Which version of VoiceGuide are you using? Can you post the MS Access database that is used so that we can try to reproduce the problem? Share this post Link to post
